Okay, I bought ek with a 98 JDM Type R...
Old Oct 20, 2005 | 01:59 PM
summit's Avatar
Default Okay, I bought ek with a 98 JDM Type R...
This is my first post, and I have done plenty of searching. Help or a point in the right direction would help.
The car has a spoon chipped P30, AEM CAI, Apex WS exhaust, DC header, AEM cam gears. The car is running super rich, and I am wondering what steps I should take to fix the problem.
I know these motors run rich, but to smell the gasoline coming through the exhaust, is that normal? The bumper has carbon all over and brownish stains around the exhaust too.
Gas mileage is not that great either.
Would VAFC help things out? Ignition/spark? I am new to Hondas/Acuras, so any help would be appreciated.
Thanks.
Old Oct 20, 2005 | 02:17 PM
255.255.255.255.'s Avatar
Default Re: Okay, I bought ek with a 98 JDM Type R... (Racebred H)
Look at your plugs, then I would look at the timing, then turn your attention to that ECU.
Old Oct 20, 2005 | 02:27 PM
summit's Avatar
Thanks for the quick replies. I will check the timeing, since I just bought the car I will change the plugs and wires anyways. I will look at the plugs first.
Old Oct 20, 2005 | 02:29 PM
Jon D's Avatar
Default Re: Okay, I bought ek with a 98 JDM Type R... (summit)
get rid of that chip would be my advise...then find a P73 for your car!
Old Oct 20, 2005 | 03:09 PM
summit's Avatar
Default Re: Okay, I bought ek with a 98 JDM Type R... (Jon D)
The chip is glued into the ecu on both sides, What is the advantage of the p73 over the P30, and will it work with the JDM motor, since the p30 I have is a JDM ecu?
Old Oct 20, 2005 | 06:50 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by summit &raquo;</TD></TR><TR><TD CLASS="quote">The chip is glued into the ecu on both sides, What is the advantage of the p73 over the P30, and will it work with the JDM motor, since the p30 I have is a JDM ecu? </TD></TR></TABLE>
sounds like you bought a car you have no friggin clue about.
good luck.
Old Oct 20, 2005 | 07:27 PM
Kendall's Avatar
May I suggest investing in some quality engine management. Just because it says "Spoon" doesn't mean it's better.
Old Oct 20, 2005 | 07:38 PM
KayOs's Avatar
invest in a quality tune and I am sure your problems will end. Good luck-
Old Oct 20, 2005 | 07:54 PM
nholmes's Avatar
Try the hybrid forum?
Old Oct 20, 2005 | 08:15 PM
92TypeR's Avatar
FSAE
Default Re: (nholmes)
Get rid of the chip. That is your problem I am 99.9% sure. Who knows what program it is running!
Old Oct 20, 2005 | 09:23 PM
summit's Avatar
Edit/ just found out that the p73 is a JDM ecu, so does it matter that whether or not I use a JDM or USDM ecu?
Thanks for the "I know more than you" attitude Ken doll and 255...
You two are right, as I said in the beginning, I am new to honda/acura. When I purchased the car I got what came with it (spoon chip).
As far as having a clue, well I am bright enough to seek advice.
Rather than make everyone that isn't familiar with something, e.g Acura/honda ecu's, feel like they sound stupid, spend more time ignoring the threads that you don't have advice for, because it really is just a waste of your genius mind's time.
The only reason I figured that the USDM ECU wouldn't work is because, a friend let me use his with a mugen chip, and it threw a CEL. Put the P30 back in no CEL.
Thanks to everyone who offered advice, and thanks for sparing the sarcastic remarks, I appreciate it.
Modified by summit at 11:04 PM 10/20/2005
Old Oct 20, 2005 | 10:10 PM
rodimus's Avatar
Default Re: (summit)
i happen to have a kenji p28 for sale
yes yes..shameless plug..but if you want good gas mileage get what everyone else said.
Old Oct 20, 2005 | 11:42 PM
B7AudiA4's Avatar
yo.. your ECU is making you spit out the gas =D
DC race header?
you sound like a true N/A racer =D
Old Oct 21, 2005 | 07:50 AM
summit's Avatar
Thanks for the replies, I have someone who will be taking care of the problem for me.
Old Oct 21, 2005 | 08:00 AM
SecretAgent's Avatar
to answer ur question everyone seems too stuck up to answer, yes, you do need the JDM P73 ecu. if you try hooking up a stock USDM ecu to ur car it will not run properly. VTEC will not engage due to no VTEC oil pressure switch on the JDM motor.
my recommendation tho is getting a custom tune done with hondata or neptune. the benefits are ten fold.
Old Oct 21, 2005 | 09:41 AM
Addicted2Racing's Avatar
Default Re: (SecretAgent)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SecretAgent &raquo;</TD></TR><TR><TD CLASS="quote">to answer ur question everyone seems too stuck up to answer, yes, you do need the JDM P73 ecu. if you try hooking up a stock USDM ecu to ur car it will not run properly. VTEC will not engage due to no VTEC oil pressure switch on the JDM motor.
my recommendation tho is getting a custom tune done with hondata or neptune. the benefits are ten fold.</TD></TR></TABLE>
^^^ YES!
B18dudeg
Feb 10, 2011 05:51 AM
efjones9
13
Sep 11, 2008 09:01 PM
DriveSlowHomie
Dec 6, 2004 11:23 AM
EG2 SiR
12
Oct 23, 2003 08:44 PM
Carlito Brigante
Oct 3, 2002 10:20 AM
