Chip p75 ecu???
Old Oct 20, 2005 | 01:37 PM
psegs80's Avatar
Default Chip p75 ecu???
I'm currently putting my 98 jdm b18b engine together...I am putting p30 pistons ( bring my comp to 11.01:1 or more because of the jdm combustion chamber), crower 404 cams with crane springs and retainers, skunk 2 cam gears + arp rod bolts and arp head studs!!! I have also act stage 1 clutch + I/H/E!!
Is getting my obd1 p75 ecu chipped with dyno time good enough for this setup or should I be looking at hondata???
Thnaks
Old Oct 20, 2005 | 02:13 PM
JCushing's Avatar
Default Re: Chip p75 ecu??? (psegs80)
you should look into hondata, uberdata, chrome for obd1, or turbo edit if your obd0.
at least 3 of those setups you will be able to tune it yourself on the dyno for basically nothing for the software with nothing more than a chip burner (ebay 50 bux) and a cheap laptop. for any of them you will need to have your ecu socketed.
if you feel like spending more money you can pay someone else to tune it for you by a hondata tuner.
Old Oct 20, 2005 | 02:40 PM
2k.civic.si's Avatar
Default Re: Chip p75 ecu??? (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">you should look into hondata, uberdata, chrome for obd1, or turbo edit if your obd0.</TD></TR></TABLE>
its crome not chrome and crome has a better statistics engine then all of the above
Old Oct 22, 2005 | 06:32 AM
psegs80's Avatar
Default Re: Chip p75 ecu??? (2k.civic.si)
Thanks I will look into it!!!
inh
Apr 19, 2006 08:30 AM
rocketfuelcerx
Jan 31, 2005 08:19 PM
SofaKing
Dec 28, 2003 08:48 AM
tweekerz
Nov 21, 2003 02:25 PM
incognitoracerr
Sep 6, 2003 07:39 PM
