Nos with A/T?
Old Mar 6, 2002 | 02:37 PM
crxgurlllll's Avatar
Default Nos with A/T?
Old Mar 6, 2002 | 02:41 PM
KoRE's Avatar
Default Re: Nos with A/T? (eraser)
My integra was auto and i ran a 75 shot with it
Old Mar 6, 2002 | 02:42 PM
Default Re: Nos with A/T? (KoRE)
how do you shut off the nos when it shifts???? or do you????
Also how do you launch with an A/T?
Old Mar 6, 2002 | 03:12 PM
Krow's Avatar
Hey eraser you should talk to teken he is running a 150 shot on his auto teg, he might be able to help you out.
Old Mar 6, 2002 | 05:13 PM
KoRE's Avatar
Default Re: Nos with A/T? (Krow)
i hooked up a button into the circuit of the switch so it wouldn't be complete unless i was holding down the button.
then i just let go when it was about to shift. then pressed it down after.
depends how big of a shot your gonna run but with mine i just floored it off the line till i got traction then i sprayed
Old Mar 7, 2002 | 06:32 AM
88_SC_CRX_Si's Avatar
New User
Auto's are better for N2O, because your not dropping out of WOT to shift. Like you would be with a manual. So there is no turning it off, until you quite flooring it....
Old Mar 7, 2002 | 07:58 AM
EL Vap133's Avatar
Hey eraser, why are you trying to cheat now? You can't add NOS to run my car foo...
Old Mar 7, 2002 | 08:01 AM
Mugen Dom's Avatar
Default Re: Nos with A/T? (Vap133)
most domestics who spray use autos its safer to use on an auto trans car since u cant miss a gear
Old Mar 7, 2002 | 08:37 AM
marty's Avatar
Default Re: Nos with A/T? (jdmB18hatch)
yeah but since its a honda the tranny might not be able to handle getting shot up.
you might need to have it re-built or re-inforced for forced induction.
Old Mar 7, 2002 | 08:40 AM
Default Re: Nos with A/T? (MugenEF7)
i think i can safely go up to 150...anything over that would prolly kill it... Its got an EX tranny(bigger bearings etc) so itll handle a little more than a dx one would...
Old Mar 7, 2002 | 08:41 AM
marty's Avatar
coo sounds good
Old Mar 7, 2002 | 08:54 AM
Mugen Dom's Avatar
good luck with it have a standby tranny just incase
Old Mar 7, 2002 | 08:56 AM
marty's Avatar
yep... have one on the side just in case this one goes awol on you.
Old Mar 7, 2002 | 10:36 AM
CRX-RX's Avatar
Default Re: Nos with A/T? (beatdown88hf)
Ya, I hear nitrous on auto transmissions is great for people who don't know how to drive and would most likely blow their cars up in any other case You just put the little stick in the middle of the car into the spot that says, "D" and step on the gas until you don't want to go anymore.
Old Mar 7, 2002 | 10:43 AM
Default Re: Nos with A/T? (CRX-RX)
Cause you know ive never driven a stick and im dumb as a doorknob right? you know me guy!
[Modified by eraser, 11:43 AM 3/7/2002]
Old Mar 7, 2002 | 10:49 AM
EL Vap133's Avatar
ROFL!!! You can't drive stick eraser!!
Old Mar 7, 2002 | 01:11 PM
nikitad's Avatar
I know you! Never seen you drive a stick.
You can hook up NOS to a sunroof switch, I can sell you one.
Old Mar 7, 2002 | 02:11 PM
EL Vap133's Avatar
Default Re: Nos with A/T? (nikitad)
HAHAHA, what's up Nikita??
Old Mar 7, 2002 | 02:17 PM
CRX-RX's Avatar
I don't have to know you, you wasted your money on an auto honda, and now you're wasting our time with it!!! What more is there to know? I don't care if you own the worlds fastest car and are an accomplished auto-X champion, you bought an auto honda [EDIT] ...and yu put more money into it [/EDIT]
[Modified by CRX-RX, 5:19 PM 3/7/2002]
Old Mar 7, 2002 | 02:33 PM
nikitad's Avatar
Hey Vap, Beatdown! Whats up.
No, I didn't go yet. But to wait untill you go is too long also.
I might go there tomorrow, or in a day. Will drive through LA, prolly stay for the night in LA.
Old Mar 7, 2002 | 02:35 PM
I put money into it just like i would any car...all of the mods i have on it can be transfered to a manual car....
Plus its not bad for a daily driver... Sitting in LA traffic with a clutch is a bitch...
Old Mar 7, 2002 | 02:38 PM
nikitad's Avatar
CRX-RX,
you may be right , but I can't understand what's wrong with buying an auto honda?
Care to explain?
Honda is not a fast car anyways, most people know.
Old Mar 7, 2002 | 10:55 PM
CRX-RX's Avatar
Automatic honda's are very unresponsive because they don't have enough torque to move the transmission through the gears very quickly or effectively. Also, due to the small HP and Torque numbers that stock honda's develop, the loss percentage of an automatic transmission becomes much larger and indespensible than with a larger V6 or V8 type engine. Honda also did not design their automatic transmissions with effective power delivery, so the gearing in the auto's tends to be more concentrated on gas mileage around town and freeway driving, neglecting everything in between. If built properly, and force inducted, an auto can be made somewhat effective because you are dealing with such large HP and Torque numbers that the percentage of loss becomes acceptible, and the tendency of the auto to be sluggish off the line only helps to keep big HP on the ground.
manuel3655
Dec 19, 2008 09:15 AM
95 honda8
18
Jun 28, 2007 10:57 AM
HandoEX
Oct 20, 2005 07:51 PM
d8168055
11
Aug 17, 2002 12:18 PM
crookedletterd
Sep 22, 2001 11:01 PM
