obd1 code testers?
Old Oct 19, 2005 | 11:37 PM
vtecpsyco's Avatar
Default obd1 code testers?
i have a b16 with a chipped p28,do they make code testers that i can buy to use on my car.i have a cel and have no clue what it is
Old Oct 20, 2005 | 12:53 AM
EKCRX-Ihadastupidusername's Avatar
Default Re: obd1 code testers? (vtecpsyco)
It should be 2 thick wire bundles by the ECU harness with blue tips. One has 2 holes, the other has 3. Stick something into the 2 outer holes of the 3 hole conncetor, like an unfolded paper clip. Turn the key to ACC. Then read the codes. If you can't read the codes, search.
Old Oct 23, 2005 | 12:39 PM
vtecpsyco's Avatar
i think its a obd11 wiring harness because it only has the connector with 2 not 3
Old Oct 23, 2005 | 12:43 PM
nocturnaldragon's Avatar
Check out the ECU thread at the top of the forum
ZombiePharoh
Engine Management and Tuning
Mar 29, 2012 02:12 PM
Lucky-13
21
Mar 22, 2007 05:27 AM
Mr Aryan
Jun 3, 2006 04:16 PM
ekmotorfiend
Mar 3, 2006 08:27 AM
RACEPAK
Dec 3, 2005 02:55 AM
