HID's In Projector's?????????
Old Mar 6, 2002 | 02:01 PM
Evil_Wizard's Avatar
Default HID's In Projector's?????????
I have a set of DENJI projector's and was wondering if I can do the HID kit in both the low beam and the high beams? Also what would the bulb number be? And does anyone know a way to make both the low beam and high beam come on at the same time without having to hold the switch down? I want the 7000k series on low beam and the 4300k series on the high beams? Yes or no please give me your opinions..... thanks
Old Mar 6, 2002 | 02:15 PM
tFUnK's Avatar
Default Re: HID's In Projector's????????? (Extreme_Hybrid_Hatch)
usually HIDs are only for the low beam... i don't know if you can have the low and high on at the same time, probably have to play with the wires... im sure if u wanted to put HIDs in both low and high you could... but personally i hate people who drive with their high beams on
Old Mar 6, 2002 | 02:33 PM
I did a search on this and i found some threads that says that there are some high beam kits available. The one i saw was 9005 bulb. I would like it in low beam and high beam for my projectors. If anyone knows what the buld numbers are in denji projectors would you please let me know. Thank you
Old Mar 6, 2002 | 02:47 PM
B2FiNiTY's Avatar
Do you already have the projectors are you car? If so, just use the HID bulbs that are the same. For example for a 94-01 Integra
Low beam: 9006
High Beam: 9005
HID lowbeam: 9006
HID high beam: 9005
For projector lenses you will also need to get D2S bulbs rather than D2R.
Old Mar 6, 2002 | 04:52 PM
Default Re: HID's In Projector's????????? (B2FiNiTY)
Ok Then I need to know where to get H1 and H3 HID kits I want the H1 in 8000k series and the H3 in the 4300k series. DOes that sound OK? That way I can have the blue look while I am driving normal and the brighter white look when I need the high beams. Right or am I confused here?
Old Mar 6, 2002 | 06:13 PM
Denny317's Avatar
H1 is your low beam or high beam?
Old Mar 6, 2002 | 06:31 PM
Default Re: HID's In Projector's????????? (Denny317)
h1 is low beam
Old Mar 7, 2002 | 08:47 AM
Nobody knows where a good company to get these HID kits is do you?
Old Mar 7, 2002 | 09:53 AM
bps2799's Avatar
VisualDynamics
composurey
Apr 11, 2012 10:36 AM
itsmejto
Jun 22, 2008 04:11 AM
myhondaaccord03
Lighting
17
Mar 22, 2008 07:01 AM
Spartan500
Sep 6, 2007 06:07 PM
kriptik
Feb 8, 2005 01:34 PM
