maintenece questions
Old Oct 19, 2005 | 08:00 PM
elitetuning's Avatar
Default maintenece questions
i have a swapped b16 second gen in my coupe and i wanted to do some maitnence work on it i plan on buying a top end gasket kit and timing belt kit with new hoses from inlinefour.com
http://inlinefour.com/timingbeltkits.html
http://inlinefour.com/topgaskit.html
i wanted to know the time you would think it ould take mor a entry level mechanic to do it i am currebtly employed at honda and go to school at a technical scool eith i wanted to do it or a shop can anyone give me a price on this type of work to be completed
Old Oct 20, 2005 | 04:53 AM
dognutz's Avatar
Default Re: maintenece questions (elitetuning)
Try using more punctuation. It will make your sentences easier to read. The hoses you should be able to do in an hour or two. The timing belt can be tricky if it's your first time. It's not hard though. I would say anywhere from 2-5 hrs for the timing belt and rubber gaskets. I would leave the head gasket and exausht gaskets alone if there is no leaks or anything.
Old Oct 20, 2005 | 05:21 AM
sorry abount the sentences it was late last night when i typed it thanks for the info
Old Oct 20, 2005 | 05:42 AM
snatch's Avatar
Default Re: (elitetuning)
I would stick with OEM for the timing belt, just my opinion. I wouldn't change the gaskets either unless something is wrong.
92f22a6
Mar 8, 2014 06:26 PM
03EM2guy
Aug 30, 2010 04:38 AM
doostin
Feb 1, 2009 04:45 PM
fro
Dec 21, 2004 12:56 PM
Piston_Honda
12
Feb 21, 2002 06:18 AM
