broke some stuff... need help
Old Oct 19, 2005 | 07:52 PM
david
Guest
Posts: n/a
Default broke some stuff... need help
i've broken the studs on the portion where you install a header/exhaust manifold. i purchased something like the EZ-out i read about but the thing is, how the heck am i supposed to use it? a drill will not fit in there and i do not have air tools (air rachet)
Old Oct 19, 2005 | 07:53 PM
Alex_SiR's Avatar
Default Re: broke some stuff... need help (david)
Owned
Old Oct 19, 2005 | 07:55 PM
coquitlamEG's Avatar
Default Re: broke some stuff... need help (Alex_SiR)
That sucks! Is there anything left sticking out of the head or did it break inside the head?
Old Oct 19, 2005 | 07:58 PM
david
Guest
Posts: n/a
Default Re: broke some stuff... need help (coquitlamEG)
i snapped it off installing the header. i swear i barely turned it. there is enough sticking out... but i don't see how the hell i'm going to attach these bits to a drill and getting this **** out.
Old Oct 19, 2005 | 08:01 PM
I'm just wondering if there's enough sticking out to get a pair of vice-grip pliers on it and twist it out. It's happened to me before too and the pliers saved my life. They say to always replace those studs and nuts with new ones becuase they get pretty stressed from heating up and cooling down all day. Now i know why.
Old Oct 19, 2005 | 08:07 PM
david
Guest
Posts: n/a
i have ghetto visegrips not going to clamp onto a steak.
anyway, i wanna replace all of them. i barely turned it and snapped. to make it worse, i broke 2 of them. bumpped for some more answers.
Old Oct 19, 2005 | 08:12 PM
i'd just go grab some new ones if you can. Another thig you could try is to somehow cut a slot into the stud so that you can use a slotted screwdriver bit to twist it out. Maybe a hacksaw blade or something.
Old Oct 19, 2005 | 08:17 PM
Project_DX's Avatar
if a new pair of vice-grips don't do it <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coquitlamEG &raquo;</TD></TR><TR><TD CLASS="quote">i'd just go grab some new ones if you can. Another thig you could try is to somehow cut a slot into the stud so that you can use a slotted screwdriver bit to twist it out. Maybe a hacksaw blade or something. </TD></TR></TABLE>this is a great idea, i would use a dreml (sp?) tool with a little cutting blade to put a slot in it
Old Oct 19, 2005 | 08:20 PM
Default Re: broke some stuff... need help (Project_DX)
YES!!! Dremel tool! Why didn't i think of that? That would be way easier.
Old Oct 20, 2005 | 09:19 AM
david
Guest
Posts: n/a
I actually have a grinder with a cutting disc that would actually fit in there. Almost chopped off a finger last time.
Rugger53
May 4, 2015 12:53 AM
Jdmglenn
Jan 31, 2005 09:50 AM
rice_classic
Aug 25, 2004 11:30 PM
94B18B1Teg
Mar 18, 2004 01:31 PM
pub
Mar 21, 2003 02:51 PM
