Tein Suspension
Old Oct 19, 2005 | 06:05 PM
CivicSiDriver02's Avatar
Default Tein Suspension
I'm looking to get a set of springs and shocks in the near future. Should I go with Tein Basics or SS? Or is there any others I should consider that would be in that same price range? The car would only be driven on the street and its a 4th gen.
Old Oct 19, 2005 | 08:14 PM
K-Spec's Avatar
Default Re: Tein Suspension (CivicSiDriver02)
go with either the SS or the Flex. i have an SS but i wish i had gotten the flex.
Old Oct 19, 2005 | 09:30 PM
thegeorge613's Avatar
Another good choice would be GC's + Konis.
Old Oct 19, 2005 | 10:19 PM
92wraith's Avatar
Went with Flex on mine... love it to death.
Previously was running eibach and koni.
Old Oct 19, 2005 | 10:38 PM
RudeLude95's Avatar
I had the SS on my 95 and thought they great.
Old Oct 20, 2005 | 10:58 AM
SteveoBA8's Avatar
Default Re: (RudeLude95)
I have the type basic on my 94 and i love them, kinda harsh but great on a smooth road.
Old Oct 20, 2005 | 12:06 PM
jdm_preluder's Avatar
Default Re: (SteveoBA8)
agree'd ground control coil overs and a nice set of struts my preferance for struts though are kyb agx's! just my .02 cents
Old Oct 21, 2005 | 09:23 AM
bb2prelude's Avatar
Default Re: (jdm_preluder)
flex! they include pillowball mounts, speeding install time. also, if you ever want to put your stock suspension back in, you dont need to mess with recompressing the stock spring to put the top hat back on (its sort of a bitch)
Modified by bb2prelude at 3:39 PM 10/21/2005
Old Oct 21, 2005 | 11:59 AM
SteveoBA8's Avatar
Default Re: (bb2prelude)
If you care about NVH then i wouldnt recommend the basics, they are pretty harsh over any imperfection in the road, but on a good road your in heaven!
Old Oct 26, 2005 | 08:18 PM
Sounds good. I am still undecided but I'm much closer than before. Thanks!
Old Oct 26, 2005 | 08:47 PM
K-Spec's Avatar
Default Re: (CivicSiDriver02)
tein flex, end of story
Old Oct 26, 2005 | 10:38 PM
boostedlude97's Avatar
Default Re: (khalal538)
if he isn't going to be trackin the car i don't see the need for the flex....and for pillow mounts you can order those from Tein as well
Old Oct 26, 2005 | 10:48 PM
blackdelslo's Avatar
Default Re: (boostedlude97)
I have tein SS, front strut bar, rear tie bar, rear sway bar. Lets just say im capable of taking certain corners so fast that im to scared to do it It handles really good, i cant even imagine how much better the flex is.
I felt why get konis, have to send them out to get revalved when i could spend the same and get 16way adjustable teins? And plus, isnt the adjuster on the side of the shuck UNDER the car, id rather pop the hood if thats the case.
Old Oct 26, 2005 | 11:25 PM
Default Re: (delLudeVTEC)
on my KONI's they are adjustable from the top under the hood and in the trunk. same as the SS. Koni's struts are far superior to the SS in all track situations............end of story
Old Oct 26, 2005 | 11:32 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">I have tein SS, front strut bar, rear tie bar, rear sway bar. Lets just say im capable of taking certain corners so fast that im to scared to do it It handles really good, i cant even imagine how much better the flex is.
I felt why get konis, have to send them out to get revalved when i could spend the same and get 16way adjustable teins? And plus, isnt the adjuster on the side of the shuck UNDER the car, id rather pop the hood if thats the case.</TD></TR></TABLE>
man, you were so wrong about that suspension choice if those were really your reasons for choosing the SS...
16 way adjustable teins or infinitely adjustable konis with a shitload more adjustability range...
i don't make you want to regret your choice, since on the street the SS is fine (though you should stop trying to corner at the limit on the street)--but on a track there's no comparison b/w the tein SS and a koni setup. i'll also take an OTS koni shock+GC over the FLEX too, but that's just me...
also, the konis only need a revalve if you're going above 600#/in springrates--last i checked the FLEX spring rates they were 10kg/mm and 6kg/mm (which, aside from being a terrible pair of spring rates, is less than 600#/in.)
Old Oct 26, 2005 | 11:37 PM
Default Re: (bad-monkey)
the man has spoken..........
goofydc5
11
Apr 2, 2004 11:40 AM
obsidianG35
Mar 21, 2004 05:20 PM
blkeg
46
Jan 4, 2004 07:35 PM
HATCHingMN
Sep 17, 2003 04:21 PM
LSintegra619
Apr 11, 2003 06:33 PM
