Just had the Clutch/flywheel replaced
Old Oct 19, 2005 | 05:40 PM
The Weather Man's Avatar
Default Just had the Clutch/flywheel replaced
The damn tranny is a bitch to get out.........took about 10 hours...........for the entire replacement.
There are 4 12pt 10mm bolts that hold the pressure plate........
I traveled to Autozone, NAPA, and Advance Auto Parts to find the socket - no one had it.........
They said they had to order everything - so finally, I found someone with a set of 12pt sockets.
Problems after problems after problems .........working on the top section - you know, everything we took out to get to the tranny. Anyway, it'll be done within an hour or so........
A Stage 3 - 6 puck ceramic clutch was put in along with a 8lb Fidanza flywheel........i wonder how it'll drive.......hmmm........
Damn! I didn't know we had to use 10w40 for the tranny fluid.........i was kinda skeptical about it at first - but the computer said 2.1 quarts of 10w30/40.........oh well.........
Old Oct 19, 2005 | 05:43 PM
95PreludeSi's Avatar
Default Re: Just had the Clutch/flywheel replaced (TheKingPin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKingPin &raquo;</TD></TR><TR><TD CLASS="quote">
Damn! I didn't know we had to use 10w40 for the tranny fluid.........i was kinda skeptical about it at first - but the computer said 2.1 quarts of 10w30/40.........oh well......... </TD></TR></TABLE>
Do yourself a favor and either use Honda MTF or GM/Penzoil synchromesh. Your tranny will thank you.
Old Oct 19, 2005 | 05:45 PM
Damn - the oil is already in. I'll replace it though here in a bit. Not today though - i'll buy the fluid and replace it.
Any problems with using the 10 40? I used a NAPA brand also.
Old Oct 19, 2005 | 05:59 PM
InvaderTrax's Avatar
No problems with it, but Honda MTF just works better (which is why newer Hondas use MTF instead of 10w40)
Old Oct 19, 2005 | 07:48 PM
DAMNIT! Someone dropped a bolt into the housing...........so we have to take it back out and get that bolt out..............BULLSHIT!
We had everything back together.............****...........Oh well, i'll get it done tomorrow.
Modified by TheKingPin at 11:29 PM 10/20/2005
Old Oct 20, 2005 | 04:16 AM
kulrevon's Avatar
Default Re: (TheKingPin)
Dopped a bolt into what case? how did you do that? Let us know how it drives? ie engagement, rev matching things like this.
Old Oct 20, 2005 | 07:06 AM
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">Dopped a bolt into what case? how did you do that? Let us know how it drives? ie engagement, rev matching things like this.</TD></TR></TABLE>
I have no idea - he was putting in the bolts from the top and he dropped one. I was pissed, so I just left.
I'm going to go back later today and get it done. I'll post back later tonight. I'm going to drive it around town for a while to get a feel for it. It should make a hell of a difference though.
Old Oct 20, 2005 | 07:13 AM
mgags7's Avatar
you mean he dropped a bolt inside the bellhousing??
if so just get a magnet....not hard....
told you that thing is a bioch....
Old Oct 20, 2005 | 07:14 AM
can't find it....yea its hossible
Old Oct 20, 2005 | 07:16 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheKingPin &raquo;</TD></TR><TR><TD CLASS="quote">yea its hossible</TD></TR></TABLE>
sounds like it....hahah
just take off the dust shield...if its small it will come out there, if not, get some light in through there and look through the timing hole...
Old Oct 20, 2005 | 07:20 AM
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">
just take off the dust shield...if its small it will come out there, if not, get some light in through there and look through the timing hole...</TD></TR></TABLE>
Good idea. I'll do that.
Old Oct 20, 2005 | 07:31 AM
MrBiggs's Avatar
B A N N E D
Dude you suck.
it shouldn't take that long.
Old Oct 20, 2005 | 07:32 AM
You dare talk to me this way?
I'm going to have you taken out. You ***. I'll find you - you better believe it.
Old Oct 20, 2005 | 09:02 AM
Revi's Avatar
I changed the tranny out on my SH once. Never again. Pulling the motor is 10 TIMES easier than removing just the tranny. Screw that.
Old Oct 20, 2005 | 11:56 AM
Man - we tried a magnet.
We went fishing and everything - couldn't find it. So we turned the half shaft and we heard it fall. So we definately have to take off the bell housing again. We'll start here in a minute - i'll keep updating it.
For beginners - thinking about working on trannys : Air Tools are your FRIENDS!
Old Oct 20, 2005 | 08:12 PM
Ok well its in now. It drives very well. I have a few problems though.
1: the speedometer doesn't work. Yes the sensor is plugged in.
2: the vtec doesn't work. Its 11:17 at night so i can't really check too much - and yes the sensors are plugged in.
I'm thinking it has something to do with the hondata. Since we had to disconnect the battery (don't think it should reset the ecu though).....I just came to work to pick up the laptop. I'm also throwing a code - i'll check it here in a bit when i get the laptop plugged in. Anyway, it runs very well. Hasn't stalled on me yet - i think i'm a pro already - haven't even driven 5 miles yet. But i'm going to check everything out and get back to this tomorrow morning or so.
Modified by TheKingPin at 11:31 PM 10/20/2005
Old Oct 20, 2005 | 09:39 PM
EOE's Avatar
EOE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You dare talk to me this way?
I'm going to have you taken out. You ***. I'll find you - you better believe it.</TD></TR></TABLE>
LOL!! That had to be the funnyest thing ever... that was great.
Lol let us know how the car feels now *after u fix vtec*
Old Oct 20, 2005 | 09:52 PM
Default Re: (EOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EOE &raquo;</TD></TR><TR><TD CLASS="quote">
Lol let us know how the car feels now *after u fix vtec* </TD></TR></TABLE>
will do - don't know what the hell the problem is. Its dark, cold, and raining here - so can't do anything. I couldn't even get on it because its wet out.
Anyway, I know everything is plugged up. I'm guessing a wire or two are pinched. Or I just don't have the oil pressure.......... I threw a code like i said - don't know what it is....it only comes on when i'm engine braking.
Its going to be hella nice once i get the speedo and vtec working. Who said 8lb flywheels aren't streetable? I guess i'm just a pro at driving the stick. I let three other people drive the car - and it stalled everytime. I guess i'm just that good though.........
I absolutely love that clutch - its just so crisp and "catchy".........its nice. oh yeah. It makes me want to forget about my turbo setup and go N/A. Its so tempting. I think I might seriously. 12:1 c/r setup on 94 octane
Old Oct 21, 2005 | 03:58 AM
kulrevon's Avatar
If your speedo doesnt work I am willing to guess you will throw a code 17 for the vss. and thats why your vtec doesnt work. Vtec wont work below a certain mph I want to say 5 or 15mph. so if you dont have a vss signal you wont have vtec.
Did you use your original vss or no?
also just make sure if you used a different vss that you dont have to pull out the plastic piece inside.
Old Oct 21, 2005 | 05:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">If your speedo doesnt work I am willing to guess you will throw a code 17 for the vss. and thats why your vtec doesnt work. Vtec wont work below a certain mph I want to say 5 or 15mph. so if you dont have a vss signal you wont have vtec.
also just make sure if you used a different vss that you dont have to pull out the plastic piece inside.</TD></TR></TABLE>
You are a smart man. I tell ya You made my day.......i couldn't even think of it. Its still cold and raining out - but i'm going to check everything when I get off work. Thanks by the way - you helped out a lot. Relieved some stress.
Car finally stalled on me for the first time this morning on the way to work. Damnit!
Old Oct 21, 2005 | 09:44 AM
OK. I found out the problem.
There are three wires going to a switch on the transmission - basically right between the distributor and vtec solenoid.
It has a blue, yellow, and i think green wire connected. My wires were pulled off. I don't know what that is - it looks like the reverse light switch, but mine come on. So it has to be something important.
Whatever it is - it might be necessary for the VSS to run. Some kind of neutral switch or something. Does anyone have a picture of the transaxle inside the car from the engine bay?
its the reverse light switch..........damn..........
that doesn't help at all. I can't find the problem. The vehicle speed sensor could be fucked....don't know.
Modified by TheKingPin at 2:01 PM 10/21/2005
Dcparker2929
Transmission & Drivetrain
Sep 20, 2014 11:55 PM
ganjasnack
Aug 4, 2010 11:24 AM
daroq69
14
Jul 31, 2007 02:53 PM
MugenGTR
Dec 13, 2002 02:36 AM
