Block differences. LS vs ITR
Old Oct 19, 2005 | 07:55 AM
miller.91.HB's Avatar
Default Block differences. LS vs ITR
Besides oil squirters and the main girdle what other differneces are there in an ITR block that are not in the LS or vice versa.
Old Oct 19, 2005 | 07:59 AM
BlueR's Avatar
Default Re: Block differences. LS vs ITR (miller.91.HB)
crank, pistons, rods
Old Oct 19, 2005 | 08:00 AM
.RJ's Avatar
.RJ
Default Re: Block differences. LS vs ITR (BlueR)
oil cooler, timing belt, water pump, oil pump, oil pickup, oil pan.....
Old Oct 19, 2005 | 08:01 AM
BlueR's Avatar
Default Re: Block differences. LS vs ITR (.RJ)
shall we go on?
Old Oct 19, 2005 | 08:07 AM
.RJ's Avatar
.RJ
valve cover
Old Oct 19, 2005 | 08:09 AM
Dave_B's Avatar
Come on guys...the stamp on the block
Old Oct 19, 2005 | 08:10 AM
Rene M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">valve cover </TD></TR></TABLE>
Ooohh thats a big one... lol
Old Oct 19, 2005 | 08:17 AM
No that's fine. I realize that all of those things are different I was more concerned with just the block assembly. I was talking with a guy who is building a LS/Vtec but he's using the ITR crank and rods instead of the stock LS stuff. I told him that he's losing one of the benefits of an LS/Vtec, the stroke, which is what makes its torque. His argument is that it's its basically just a stock ITR block without the oil squirters. He's under the impression that he'll be able to rev higher more safely.
I think if he's gonna spend the money he should just get an ITR block. I don't see any benefit to what he's doing.
Old Oct 19, 2005 | 02:47 PM
Circuit Star-29's Avatar
You're right (stroke) and he is right. Because the R crank is balanced w/ weights, it can handle a higher rev range and operate smoother at that range. But, I think hes an idiot because for the cost of the R crank he could've had his LS crank balanced, lightened and chamfered.
Old Oct 19, 2005 | 06:07 PM
TypeSiR's Avatar
Default Re: Block differences. LS vs ITR (C-speed Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-speed Racer &raquo;</TD></TR><TR><TD CLASS="quote">You're right (stroke) and he is right. Because the R crank is balanced w/ weights, it can handle a higher rev range and operate smoother at that range. But, I think hes an idiot because for the cost of the R crank he could've had his LS crank balanced, lightened and chamfered.</TD></TR></TABLE>
we must all agree with this one!
riceball777
Mar 7, 2010 03:26 PM
boostincoupe
Feb 29, 2008 03:52 PM
SOUNDEFFECTS
Dec 15, 2004 12:41 PM
Phoenix1
28
Jan 16, 2004 03:00 PM
