noise in the tranny
B A N N E D
From: Orange County / Palm Springs 714/76hoe, ca, usa
i have a b16 tranny n i was jus driving dthen all of a sudden trannys making noise sound s like gears or something anybody selling their tranny over here or someone knows how to fix it they told me is jus a main bearing aight thanks
i have the same problem. tranny making noise. i swapped by stock d-series motor back in and its making a lot of noise now. mostly, in first and second gear, the most noise is going on. making the same noise as yours. the noise goes away when i step on the clutch even when in neutral. once i release the clutch in any gear, it makes all this noise. on the highway, 3-5 gear are ok..not too much noise.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d_SUPAl1l »</TD></TR><TR><TD CLASS="quote">i have the same problem. tranny making noise. i swapped by stock d-series motor back in and its making a lot of noise now. mostly, in first and second gear, the most noise is going on. making the same noise as yours. the noise goes away when i step on the clutch even when in neutral. once i release the clutch in any gear, it makes all this noise. on the highway, 3-5 gear are ok..not too much noise.</TD></TR></TABLE>
Your noise sounds like a mainshaft bearing. Either the input shaft bearing, or one of the other bearings inside the tranny.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon95eg »</TD></TR><TR><TD CLASS="quote">yeah am when im driving if i stop no noise no noise too if i step on the clutch or let go</TD></TR></TABLE>
So yours only makes noise when you are driving? Not when you're stopped AT ALL? Have you checked your tranny fluid? Start there.
tranny fluid. i put some in and drove around for a bit and it quieted down. you wont feel a difference in the noise until the fuild breaks in. i guess that i forgot to put some tranny fluid in when i swapped the stock motor in. try that...it should work
eh9deux
Apr 13, 2010 09:58 AM
