Stuck key
Old Oct 19, 2005 | 06:12 AM
floriudabrain's Avatar
Default Stuck key
I just changed my ignition switch in 95-lx, I can not get the key to turn past the "I" position to "O" so I can get the key out. Am I totally retarded or am I missing something, Help!
Old Oct 19, 2005 | 07:11 AM
jokestar's Avatar
i have the SAME EXACT problem...i havent replaced the ignition switch yet, i unplugged it and the key still wouldnt come out, hopefully somebody can help both of us?
Old Oct 19, 2005 | 07:21 AM
Default Re: (jokestar)
I just unplugged the beeper/warning plug, the grey plug on the igniton switch harness and the key works fine, as soon as I plug in the grey plug, I can't get the key out of the ignition.
Old Oct 21, 2005 | 08:13 PM
db8xc1x39
Guest
Posts: n/a
Default Re: (floriudabrain)
does it happen even when you jiggle and push the key in and turn??
Old Oct 21, 2005 | 08:41 PM
Schmitey's Avatar
Default Re: (db8xc1x39)
yes you must push key in and turn. I'm assuming you got a new key with the new ignition switch?
Old Oct 23, 2005 | 08:13 AM
markski037's Avatar
if its an automatic then there should be a line from the ignition to the transmision, that tells your ignition that your transmission is in "P" and you can take the key out
Old Oct 23, 2005 | 10:57 AM
JDMcb7's Avatar
Default Re: (markski037)
one question for you guys that have this problem.. what kind of keys do you have is it the original lazer cut from the factory ones or the one cut from honda.. cause that could be your problem right there cuase its common for the key to get stuck with the original keys
TOmmy
Barf Hat
Oct 9, 2019 05:45 AM
Moog_enep3
Nov 6, 2013 11:03 AM
vware1955
Oct 16, 2008 09:53 PM
vbspunger
Jan 3, 2007 11:21 AM
tigueremalo
Aug 22, 2006 05:38 PM
