Testing waters...Selling my Custom D series Turbo setup..LoveFab/TurboXS...complete kit
Old Oct 19, 2005 | 05:10 AM
fjt's Avatar
fjt
Default Testing waters...Selling my Custom D series Turbo setup..LoveFab/TurboXS...complete kit
Well i am not sure yet if i really want to sell it but i will hear/entertain offers and if its good i'll let it go..
Money is kinda tight right now and i need to pay some bills..
*The current turbo is a T3 Super 60 but i have a brand new T3/t4e 57 trim that i was going to install so i can sell it with the new turbo and keep the super 60 to sell it later as an used turbo.
For the Moment i WILL NOT part out...But if someone would like something i can put you on a list and when all the other parts have a name/owner ready to buy theni will sell..I cant afford to sell individual parts since this is my only car and daily driver so i cant stay w/o a ride for long.
Turbo setupfor any D series motor..d16a6,D16Z6,Y7,Y8,Y5)
*LoveFab Minime Manifold A/C(Paid $750 for this)
*Turbonetics Racegate 42mm with all Springs(3-5 PSI, 5-7 PSI, 7-9 PSI, 9-13 PSI)This retails for more than $400..This is NOT a Deltagate, it is a bigger WG and will not Creep boost.The base of the WG is bigger and has a 42mm valve. I had solid Boost
*Dump tube
*Garret T3/t4e --New-- 57 trim, stage 3 wheel, 4 bolt exhaust, for external WG only. .48Exhaust/ .60Compressor.(sells usually for $500+)
*Garet T3 Super60--Used but working in good condition. 5 bolt exhaust. .48exhaust/.60 compressor
* 3" Downpipe non a/c (exits to the passenger side). Downpipe has 5 bolt flange for the Super 60 turbo but i have the 4 bolt flange that can be welded in there(in case you want the setup with the t3/t4). Downpipe has 2 Oxigen bungs and an EGT bung.
*ATP turbo Oil restrictor
*-3 AN Oil Feed Line
*-10 AN Oil Return line with fittings (xcept the fitting that welds on the oil pan, unless you send me your oil pan and i send you mine)
*ATP turbo Silicone Couplers
*ATP turbo T bolt Clamps
*Turbo XS RFL BOV
*2.5" Charge pipes(mandrel bent) will fit 96-00 civics..Might fit 92-95
*Intercooler -- 31" X 6" high x 2.75 with 3" end tanks and 2.5 in/outlets
*Turbo Smart MBC
*Autometer Boost Gauge
*Autometer EGT(Pyrometer)
*DSM 450cc injectors(Blue tops)
*Resistor Box
Manifold/Super60/Racegate
Installed on carNota that is just a test fit shot..as you can see the WG is not positioned like its supposed to go. I also made a flange to be able to rotate the WG 90 degrees)
Misc parts (i can sell these separatelly)
*2.5"-3" test pipe..It is a flared pipe that bought from K teller but never used it.
My motor is a Y7 with 100% stock head. I made with this setup 266whp and 240lbs ft on full exhaust and 93 octane, with the Super 60 turbo at 18PSI..this setup is well capable of doing more than 300whp with the T3/t4.
I ran 12.4 @ 111mph with Pupm gas/full exhaust and full interior.Tuned with Uberdata
Block is built with pistons(vitaras) and Eagle rods but i dont think ill sell those as id have to open the motor and i dont want to do that.
If anything is missing i will add it up later
Im open to Offers so let me know..Please no low balling.There is well over $2500 invested in all these listed. Buyes pays shipping costs from Puerto Rico to your destination.
Lastly..I have sold to MANY members here. I have plenty of vouches and i am known for being responsible and i take good care of my customers. Vouches availble
Old Oct 19, 2005 | 08:28 AM
fjt's Avatar
fjt
bump
Old Oct 19, 2005 | 06:52 PM
mr_hahn73's Avatar
Default Re: Testing waters...Selling my Custom D series Turbo setup..LoveFab/TurboXS...complete kit (fjt)
bump on a badass setup
Old Oct 20, 2005 | 05:28 AM
fjt's Avatar
fjt
Thanks for the bump
Old Oct 20, 2005 | 10:01 AM
fjt's Avatar
fjt
bump
Old Oct 20, 2005 | 10:12 AM
EJ1 wilcox's Avatar
Default Re: (fjt)
Damn. So sad to see it go.
I was upset for a week after I decided to sell my turbo kit. I was in the same situation, needed the money.
Old Oct 20, 2005 | 11:24 AM
fjt's Avatar
fjt
Default Re: (EJ1 wilcox)
well as i said i will just sell it if i can sell it all..
I am also looking to get a more comfortable,bigger car but that still has a good punch **cough SRT-4 Cough**
Old Oct 20, 2005 | 07:45 PM
joboost13's Avatar
Default Re: (fjt)
nice setup, cuanto meng?
Old Oct 21, 2005 | 04:32 AM
fjt's Avatar
fjt
Default Re: (joboost13)
Pm'd
Old Oct 22, 2005 | 07:03 AM
fjt's Avatar
fjt
all pm's responded
Old Oct 23, 2005 | 12:16 PM
blkhtch98's Avatar
Default Re: (fjt)
NICE SET UP!!!!!!!!
Old Oct 24, 2005 | 07:42 AM
fjt's Avatar
fjt
Default Re: (blkhtch98)
Bump
Old Oct 25, 2005 | 04:31 AM
fjt's Avatar
fjt
**Intake Charge pipe is diferent now**
Old Oct 25, 2005 | 05:34 AM
SOHCex20's Avatar
Default Re: (fjt)
Pm sent. Bump for a bad *** set up.
Old Oct 26, 2005 | 09:03 AM
fjt's Avatar
fjt
Default Re: (SOHCex20)
Old Oct 27, 2005 | 05:07 PM
akkord_sirt's Avatar
Default Re: (fjt)
you planning on selling your motor too?
Old Oct 28, 2005 | 04:01 AM
fjt's Avatar
fjt
no i wont sell the motor..Ill probably put the car back to stock and sell it...Unless someone interested in the whole car as it is, with the turbo installed and the hatch running low 12...
That be better
Old Oct 28, 2005 | 06:42 AM
fjt's Avatar
fjt
Well this is on hold right now..
There is someone locally interested in buying the Whole car with the turbo installed and runing 12's...
so unless he flakes out all these parts are on hold.
Old Nov 2, 2005 | 08:29 PM
CelicaGT-S's Avatar
Default Re: (fjt)
Check Pm's
Old Nov 15, 2005 | 01:02 AM
trickmaster505's Avatar
pmed
Old Nov 16, 2005 | 09:03 AM
fjt's Avatar
fjt
Default Re: Testing waters...Selling my Custom D series Turbo setup..LoveFab/TurboXS...complete kit (trickma
responded ell pm's
kermit
Nov 22, 2005 09:42 AM
bboylude
Jun 18, 2003 05:11 PM
