Hazard Fuse
I was helping someone I know with a 4th gen. For some odd reason, her hazard fuse keep on getting burned out everytime he turn on the hazard but when she just turned on the signal lights, the fuse is okay. Anyone know how to solve this problem? Thanks a lot guys.
had the same problem too.. i just replaced a new fuse and the citylights are on.. then when i test turning on the hazard..the fuse blow up again..
still searching for some answer though.. anyone had an idea?
totally forgot to update this,.. the problem was a short circuit on the cluster (which I have no idea which part of the cluster gauge) because it happened when I change the old cluster to a new one with tach but eventually put it back and the no more fuse blown.
Well don't u want to keep the new cluster? (I assume the new one is an EL cluster vs analog)
I can help with that- long ago I did an EL cluster swap in one of my old preludes with the stock 92-93 harness and had to splice and cut into everything. Do u need wiring diagrams?
smokinsi
10
Sep 1, 2004 08:43 AM
