INTERIOR LIGHTS DONT WORK.
Old Oct 18, 2005 | 01:32 PM
miamijdmcoupe524's Avatar
Default INTERIOR LIGHTS DONT WORK.
MY INTERIOR LIGHTS ON MY EK COUPE DONT WORK. IM TRYING TO FIGURE IT OUT THIS WEEKEND. WHEN I SAY NONE I MEAN NONE. AT NIGHT THE ONLY THING THAT LIGHTS UP IS THE RADIO. LET ME KNOW ASAP
Old Oct 18, 2005 | 01:49 PM
DAMN 15MINS AND AT THE BOTTOM. BACK TO THE TOP....
Old Oct 18, 2005 | 01:51 PM
92ehatch's Avatar
Default Re: (miamijdmcoupe524)
stop using ur capslock key, i can read lowercase just fine
check your fuse
Old Oct 18, 2005 | 01:52 PM
JDM-EJ1's Avatar
Default Re: (93egsedan)
Check fuses.
Old Oct 18, 2005 | 01:56 PM
CHECKED FUSES AND NOTHING....
Old Oct 18, 2005 | 01:59 PM
hondaboy4life's Avatar
check ur light bulbs... lol maybe u blew all of em check all ur fuses and make sure none are blown...
Old Oct 18, 2005 | 02:03 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miamijdmcoupe524 &raquo;</TD></TR><TR><TD CLASS="quote">CHECKED FUSES AND NOTHING....</TD></TR></TABLE>
If it's not the fuse (and I know it is). I find it impossible for ALL your interior ligts to go out at the exact same time.
Old Oct 18, 2005 | 02:05 PM
JDM-EJ1's Avatar
Default Re: (JDM-EJ1)
If it just your dash lights, try your dimmer switch. If that thing is bad, none of your dash lights will work.
Old Oct 19, 2005 | 03:28 PM
i tried the dimmer switch i picked up at a yard. the damn thing started to burn on the inside.
Old Oct 23, 2005 | 12:17 PM
everytime i put the dimmer switch in it i smell it burning. when i do the input test for the dimmer switch it blows the fuse. any ideas here would be helpful
Old Oct 23, 2005 | 01:02 PM
Miss Kawasaki's Avatar
You may have shorted something out with that switch now that it has burned. Take a minutes and follow your wires back and make sure no other wires were affected from that switch.
You dont have any type of fuse box under your hood do you?
I've seen stranger things in cars before.
But check all your wires first you may have a short somewhere in your lines
Good Luck
duscar
Mar 19, 2011 03:20 PM
Luke G.
10
Sep 27, 2009 08:32 AM
mel
12
Nov 9, 2006 09:04 AM
Marcos
Mar 23, 2004 11:21 AM
bo0sted
Oct 18, 2003 02:30 PM
