Anyone have any idea how to remove anodizing?
Old Oct 18, 2005 | 01:24 PM
MidwestSi's Avatar
Default Anyone have any idea how to remove anodizing?
If this is in the wrong forum please move. Does anyone have any idea
Old Oct 18, 2005 | 04:27 PM
BigMoose's Avatar
Default Re: Anyone have any idea how to remove anodizing? (MidwestSi)
Can of Easy-Off™ Heavy Duty Original Oven Cleaner will typically do the trick. Usual sound safety precautions apply. Chemical resistant gloves, eye protection good ventillation...
The oven cleaner is lye, spray it on, scrub with toothbrush or other suitable brush, rinse it down. No more than a few, like a couple of minute. soak.
Old Oct 18, 2005 | 06:30 PM
Sliced Beard's Avatar
Default Re: Anyone have any idea how to remove anodizing? (BigMoose)
Oven cleaner will weaken the aluminum that you spray it on which is why the can explicitly says DON NOT USE ON ALUMINUM. Just be sure that whatever you use it on is not a structural part. It will also most likely leave a rough textured surface behind.
I suggest just sanding it off if you don't want to risk it.
Old Oct 18, 2005 | 07:47 PM
nutar's Avatar
Aircraft stipper
Old Oct 18, 2005 | 07:48 PM
Default Re: Anyone have any idea how to remove anodizing? (nutar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutar &raquo;</TD></TR><TR><TD CLASS="quote">Aircraft stipper</TD></TR></TABLE>
is only good for paint and old powdercoat
gutted-dx
Oct 1, 2005 01:44 PM
kniob
Jul 13, 2005 11:22 AM
Honda_18
25
Dec 5, 2004 02:38 PM
ITRFetish2000
May 27, 2004 08:26 AM
AL ASPIRATED
May 11, 2004 05:50 AM
