where do these 2 connectors go... HELP havent slept in 33 hours!!
Old Oct 18, 2005 | 11:16 AM
JDMlyfestyle's Avatar
Default where do these 2 connectors go... HELP havent slept in 33 hours!!
OK im really starting to slip up now.. im reinstalling my harness and im soo tired and confused i have no clue where these 2 connectors go. i think one might be for vtec but not sure which one.
Ok connector one is a single wire and its red with a green plug
Connector # 2 is a 2 wire. with a power and ground and green plug.
Old Oct 18, 2005 | 11:29 AM
Kouki-EK9's Avatar
Default Re: where do these 2 connectors go... HELP havent slept in 33 hours!! (JDMlyfestyle)
The single wire could be the knock sensor, do you have the KS hooked up already? The two wire one will fit on the black thing on the back of the intake manifold, I don't know what it's called but that might be it.
Old Oct 18, 2005 | 11:32 AM
gftgrill's Avatar
not sure which one, but one looks like the one for the oil pressure sensor for the vtec solenoid.
Old Oct 18, 2005 | 11:35 AM
Kouki-EK9's Avatar
Default Re: (gftgrill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gftgrill &raquo;</TD></TR><TR><TD CLASS="quote">not sure which one, but one looks like the one for the oil pressure sensor for the vtec solenoid.</TD></TR></TABLE>
yeah, that's true. My car doesn't have a pressure switch for VTEC so I forgot about it. The pressure switch has two wires, so I would go with that one.
Old Oct 18, 2005 | 11:37 AM
ok i dont have a knock sensor hooked up. but there was this emissions device hooked up to the firewall that connected to the charcoal canister
Old Oct 18, 2005 | 11:42 AM
Kouki-EK9's Avatar
Default Re: (JDMlyfestyle)
You don't have a knock sensor at all? Or it's just not connected?
Here's a picture of someone's pressure switch on the left, there's some green in there but I think the plug itself is grey.
Old Oct 18, 2005 | 12:41 PM
i just need to know the color of the wires..lol
Old Oct 18, 2005 | 01:05 PM
sockvtec's Avatar
Default Re: (Kouki-EK9)
what kinda car is that? i see they have a/c so im guessin its not swapped, but if it is i give you props
Old Oct 18, 2005 | 01:10 PM
Kouki-EK9's Avatar
Default Re: (sockvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sockvtec &raquo;</TD></TR><TR><TD CLASS="quote">what kinda car is that? i see they have a/c so im guessin its not swapped, but if it is i give you props</TD></TR></TABLE>
It is swapped but it's not my car.
Old Oct 18, 2005 | 01:11 PM
litterbox's Avatar
I am a (Trial User) Army
That's Dawrenn's GSR swapped EJ8
Old Oct 19, 2005 | 05:44 AM
HeikDiesel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle &raquo;</TD></TR><TR><TD CLASS="quote">OK im really starting to slip up now.. im reinstalling my harness and im soo tired and confused i have no clue where these 2 connectors go. i think one might be for vtec but not sure which one.
Have you used an ohm meter to check the continuity to where it goes on the ecu? You can then use an ecu pin out to see what it controlls. Thats what I would do
Old Oct 19, 2005 | 05:56 AM
Archidictus's Avatar
Unceasing Measure
What engine/wiring harness is this?
Old Oct 19, 2005 | 07:16 AM
SkRiBLaH's Avatar
Default Re: (Archidictus)
green plug / red wire = knock sensor (100% sure)
green plug / blue-gray wire = vtec pressure (99.5% sure)
Old Oct 19, 2005 | 07:23 AM
vtecpoweredsol's Avatar
connector "number 2" should go to the vtec solenoid, i just checked mine
Old Oct 19, 2005 | 07:33 AM
Luserkid's Avatar
Default Re: (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">green plug / red wire = knock sensor (100% sure)
green plug / blue-gray wire = vtec pressure (99.5% sure)</TD></TR></TABLE>
Ill back that up.
Jason, get some sleep and come back to this later before you really screw it up.
94EGKUSH
Mar 2, 2009 09:19 AM
CrazyHB
Aug 30, 2004 06:51 PM
hughesl
Aug 18, 2003 03:34 AM
b16hybridsol
Jul 8, 2003 07:18 PM
Metal_SOL
Jul 16, 2002 11:25 PM
