injectors not opening....
Old Oct 18, 2005 | 10:26 AM
KrispyKreme's Avatar
Default injectors not opening....
I'm driving down the road and all of a sudden my car dies, after troubleshooting for a while, i find that i have fuel coming to the rail but not out of the injectors, what could be wrong?
Old Oct 18, 2005 | 11:44 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: injectors not opening.... (lshatch318)
what kind of car is it on?
do you have spark? if not you may have a distributor problem. it controls injectors as well. if you have access to a noid light plug that into your injector harnesses and see if it blinks.
Old Oct 18, 2005 | 12:31 PM
civic_driver's Avatar
Clogged injectors or the solenoid is messed up and you need new injectors. Have them professionally tested and cleaned. Could be a wiring problem as well but I doubt it.
Old Oct 18, 2005 | 01:39 PM
Default Re: injectors not opening.... (boostedcivicsir)
i am gettin spark, is there any other way to test the injector harnesses?
Old Oct 18, 2005 | 01:48 PM
Mr. Badwrench
just a noid light, they are a low current circuit.
Old Oct 18, 2005 | 01:50 PM
oh yeah its a b18b eg hatch
Old Oct 18, 2005 | 01:52 PM
DC4_MADMAN's Avatar
Test the main relay.
Try this-
http://www.honda.co.uk/owner/c...9.pdf
Old Oct 20, 2005 | 02:43 PM
tony n.'s Avatar
Default Re: (4door_demon)
i have a good idea....buy a g35 and call it a day
Old Oct 20, 2005 | 03:09 PM
Default Re: (BoostedJDMej8)
if i had money to buy a g35 then my car wouldnt be broke down ahah...
i seriously doubt that my relay is bad because it is about 2 months old....but i will try it
Old Oct 20, 2005 | 06:56 PM
tony n.'s Avatar
Default Re: (lshatch318)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lshatch318 &raquo;</TD></TR><TR><TD CLASS="quote">if i had money to buy a g35 then my car wouldnt be broke down ahah...
i seriously doubt that my relay is bad because it is about 2 months old....but i will try it</TD></TR></TABLE>
just order a fuel rail and injectors and that line
do it big
STEN_714
Dec 20, 2014 03:30 AM
Käras
16
May 10, 2011 07:23 AM
SPOOLINmatt
Sep 2, 2010 05:45 AM
KrispyKreme
Jan 4, 2006 08:39 PM
Used2beAb16
Apr 11, 2005 08:18 PM
