clutch problem searched
Old Oct 18, 2005 | 07:05 AM
acmeotally's Avatar
Default clutch problem searched
i have a 92 stock si and all of a sudden my clutch is extremely loose and doesn't start to disengage until the pedal is 3/4 of the way down. most of the time the only
way it gets in gear is by it grinding. but when it is in gear the clutch doesn't slip at all. i know i have a bad throw out bearing because of the noise it makes when it drives. i have searched but no similar threads any help would be appreciated.
Old Oct 18, 2005 | 07:59 AM
Mista Bone's Avatar
D Tranny Guru
more likely input shaft bearing, not throwout bearing.
Clutch might have spit a spring causing the grinding gears.
Does it shift fine with the engine off?
Old Oct 18, 2005 | 08:28 AM
acmeotally's Avatar
Default Re: (Mista Bone)
it shifts fine
Old Oct 18, 2005 | 09:13 AM
Mista Bone's Avatar
D Tranny Guru
likely the clutch has spit out a spring..........
now explain the noise...........
Old Oct 18, 2005 | 01:41 PM
acmeotally's Avatar
sry i asked this question without thinking or trying to fix it, because it happened right before school, so i posted during school.
when i got out i checked the fluid level and it was empty, i put fluid in and there is pedal pressure and works fine. so i obviously have a leak some where but i will figure that one out later thanks for the help.
Old Oct 18, 2005 | 01:59 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (acmeotally)
look down by the clutch pedal where it goes through the firewall, if there is fluid there, replace the master. then look down at the slave. peel the boot back. if there is fluid there replace the slave. these are 2 common occurrences.
Old Oct 18, 2005 | 02:21 PM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acmeotally &raquo;</TD></TR><TR><TD CLASS="quote">sry i asked this question without thinking or trying to fix it, because it happened right before school, so i posted during school.
when i got out i checked the fluid level and it was empty, i put fluid in and there is pedal pressure and works fine. so i obviously have a leak some where but i will figure that one out later thanks for the help.</TD></TR></TABLE>
Your master cylinder is bad. Replace it and all your problems will go away. Should be under $100 and you can do it yourself in an hour. Be sure to rebleed the system after installation.
got2
Jun 20, 2006 08:49 PM
ACottrell
Apr 20, 2005 05:01 PM
96 ls teg
Sep 5, 2004 10:28 PM
Flux
Apr 16, 2002 08:58 AM
