Help,h22 swap into 93 cx#1 not igniting
Old Oct 17, 2005 | 09:55 PM
LD_EGSICK's Avatar
Default Help,h22 swap into 93 cx#1 not igniting
(problem fix i got a different ecu)
i just drop my jdm h22 in to my 93 civic hb cx. I'm running a jdm obd1 p13 ecu and its not throwing any CEL. the problem is that #1 is not doing any thing, even though i have spark, fuel, and my compression is the same as 2,3,and 4.
what i did
spark.(using the jdm internal coil)
check the spark at the end of of the spark plug wires, and the plug(check all the gap and switching the plug from a working #(2,3,and 4).also checking the firing order. I also changed my cap,rotor,wires, and plugs with new ones and tried using the old one too.meaning cylinder 1 is sparking but its still not firing
fuel.
check my wiring in the resistor box and all connection is soldered. the injector is working as well(also tried switching the injector from the other ones. also checking the injector plug and it is working.
compression.
using the compression tester in each of 4,3,2,and 1 and all came out with 240 all the way across.
i found out #1 cylinder wasn't working because i pulled the spark plug wire while the motor was running and didn't do any difference compared to #2,3,n 4.
so what could it be?
Modified by LD_EGSICK at 4:09 PM 10/18/2005
Modified by LD_EGSICK at 7:32 AM 10/21/2005
Old Oct 18, 2005 | 02:49 AM
Slavko's Avatar
Default Re: Help,h22 swap into 93 cx#1 not igniting (LD_EGSICK)
so you have no spark at all coming from the #1 plug? And also you changed the wires right. Did you ground the spark plug when you tested it for spark? If you did all those things then all I can think of is that the timing on the distributor is off or you need a new distributor.
Old Oct 18, 2005 | 05:16 AM
high_revs's Avatar
yeah distributor is probably shot...you said no spark in cylinder #1 correct???
Old Oct 18, 2005 | 07:09 AM
LD_EGSICK's Avatar
Default Re: (SB tuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning &raquo;</TD></TR><TR><TD CLASS="quote">yeah distributor is probably shot...you said no spark in cylinder #1 correct???</TD></TR></TABLE>
there is spark but its not firing.
Old Oct 18, 2005 | 10:45 AM
Slavko's Avatar
Default Re: (LD_EGSICK)
how you know its not firing?? If its not igntiing then you have no fuel. check the injector.
Old Oct 18, 2005 | 11:32 AM
high_revs's Avatar
yeah you cant really have spark, fuel, and compression and have it not start, your missing something bro.
Old Oct 18, 2005 | 04:20 PM
LD_EGSICK's Avatar
Default Re: (Slavko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slavko &raquo;</TD></TR><TR><TD CLASS="quote">how you know its not firing?? If its not igntiing then you have no fuel. check the injector.</TD></TR></TABLE>
"fuel.
check my wiring in the resistor box and all connection is soldered. the injector is working as well(also tried switching the injector from the other ones. also checking the injector plug and it is working."
tired using a different dizzy and ecu(ecu is for AT soo I'm still going to test out a MT ecu tomorrow) today but no difference, still running on 3 cylinder.
Old Oct 18, 2005 | 09:13 PM
high_revs's Avatar
check the actual injector...maybe its shot....could happen.
Old Oct 19, 2005 | 08:37 PM
LD_EGSICK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SB tuning &raquo;</TD></TR><TR><TD CLASS="quote">check the actual injector...maybe its shot....could happen.</TD></TR></TABLE>
same thing i said on top( i tried switching the injector with a running cylinder)
Old Oct 19, 2005 | 09:12 PM
high_revs's Avatar
got me stumped...bump
Old Oct 20, 2005 | 10:32 PM
LD_EGSICK's Avatar
got my hands on a nother ecu, every thign good to go now. all 4 cylinder running. only thing that i'm not sure baot is i got a 4 plug p13, must of been from the all wheel steering prelude in japan.
Old Oct 21, 2005 | 08:40 AM
high_revs's Avatar
so it was the ecu?
slobalt716
Mar 20, 2015 12:19 PM
EG6 Love
Sep 24, 2013 09:11 AM
slowwcivic
May 25, 2011 06:18 AM
93Hammer
Dec 11, 2008 04:10 PM
aziaticvang
Jul 19, 2008 11:10 AM
