b16a with skunk 2 stage 1 cams .... slower
Old Oct 17, 2005 | 05:24 PM
Firestarter's Avatar
Default b16a with skunk 2 stage 1 cams .... slower
I have a b16a in a crx with vafc2 recent mods have been the header, completing my exhaust system & skunk 2 stage 1 cams only, I took it down the 1/4 mile track & now the car runs 15.03 as compared to 15.00 !!!!
Old Oct 17, 2005 | 05:26 PM
flesh199's Avatar
Default Re: b16a with skunk 2 stage 1 cams .... slower (Firestarter)
you tuned the car after the cam swap right???
Old Oct 17, 2005 | 05:52 PM
Autoworks's Avatar
Default Re: b16a with skunk 2 stage 1 cams .... slower (flesh199)
no tune, no power.
Old Oct 17, 2005 | 05:58 PM
what do you mean, I just thought the cams had to be replaced & fuel intake had to be bumped up a bit just to make sure the motor does not run lean, which I did with the vafc & air fuel meter. What else has to be done?
Old Oct 17, 2005 | 06:13 PM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firestarter &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean, I just thought the cams had to be replaced & fuel intake had to be bumped up a bit just to make sure the motor does not run lean, which I did with the vafc & air fuel meter. What else has to be done?</TD></TR></TABLE>
thats not a real tune.
Get it tuned the right way and you'll be set
Old Oct 17, 2005 | 06:14 PM
Autoworks's Avatar
get on a dyno and actually tune it. You could have easily made it too rich. Are you using a wideband O2, if not, then you really can't go by the a/f gauge.
Old Oct 18, 2005 | 01:55 AM
b19coupe's Avatar
You also need to tune your VTEC engagement point. It makes a big difference.
Old Oct 18, 2005 | 02:06 AM
:Andrew's Avatar
Default Re: b16a with skunk 2 stage 1 cams .... slower (b19coupe)
yeah just tune it and you can also go ahead and upgrade your valvetrain
97ex2siClone
Jun 27, 2013 11:36 PM
mca_gsr
Jun 5, 2006 02:02 AM
Creative
Aug 2, 2004 01:29 AM
nonvteckiller
10
Feb 18, 2004 09:41 AM
97RedLudeSH
Oct 31, 2001 06:47 AM
