Is my head okay?
Old Oct 17, 2005 | 10:32 AM
m R g S r's Avatar
Default Is my head okay?
I pulled the head, and I don't know what could have been ruined or signs of a bent valve. But the piston in the number 4 cylinder (the one the rod broke in) was at TDC, while the other 3 weren't. So I'm guessing the piston hit the head and stopped moving, but I don't think alot of force was involved, considering there are no marks on the piston or the combustion chamber #4.
Here are some pics.....(to confirm that nothing was ruined)
here is how the car sits now, just b.c. i like takin pics
#4:
thanks again
Old Oct 17, 2005 | 12:50 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Is my head okay? (m R g S r)
looks like it smushed the ground strap down on the #4 spark plug, could just be the pic tho
Old Oct 17, 2005 | 01:32 PM
m R g S r's Avatar
Default Re: Is my head okay? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">looks like it smushed the ground strap down on the #4 spark plug, could just be the pic tho</TD></TR></TABLE>
well i am happy if it i only have to replace my 8,000 mile old 8 series plugs lol
Old Oct 17, 2005 | 01:50 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">
well i am happy if it i only have to replace my 8,000 mile old 8 series plugs lol </TD></TR></TABLE>
I'd recommend at least inspecting the valve stems for straightness and checking the rest of the valvetrain (springs/retainers/etc) for anything out of the ordinary. Moving parts don't like to stop on a dime.
Old Oct 17, 2005 | 01:52 PM
project dc2's Avatar
spend 50 bucks.. get a machine shop to inspect it for cracks or warps .. itll b worth the headache later on.
Old Oct 17, 2005 | 04:18 PM
m R g S r's Avatar
Default Re: Is my head okay? (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">spend 50 bucks.. get a machine shop to inspect it for cracks or warps .. itll b worth the headache later on. </TD></TR></TABLE>
hmm...i dont even know of any shops that will inspect it......anyone know any near nyc...i dont wanna ship it out, and time is kinda limited, i want this running
Old Oct 18, 2005 | 07:21 AM
m R g S r's Avatar
any other opinions by looking at the pics?
Old Oct 18, 2005 | 07:43 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m R g S r &raquo;</TD></TR><TR><TD CLASS="quote">any other opinions by looking at the pics?</TD></TR></TABLE>
Looks can be deceiving.
The only surefire way to make sure it's still good is to have it checked out with the proper tools.
Otherwise, there's nothing in the pictures to indicate anything wrong. If you're feeling lucky, throw it on and hope that it holds. BTW, you might also want to play the Powerball, it's up to $340Million.
Old Oct 18, 2005 | 08:40 AM
TurboTagTeam's Avatar
Default Re: Is my head okay? (Finest)
It's hard to tell. Looks like nothing was bent, but better safe than sorry
Old Oct 18, 2005 | 10:05 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">
If you're feeling lucky, throw it on and hope that it holds. BTW, you might also want to play the Powerball, it's up to $340Million. </TD></TR></TABLE>
nOice....im throwing it on and playing powerball......
if it is bad, then ill use the money i win to build it
Old Oct 18, 2005 | 10:11 AM
Stewie's Avatar
i've heard of people using kerosene to see if the valves are sealing.
Old Oct 18, 2005 | 10:35 AM
Andres-eh2's Avatar
Westchester Crankshaft. Think its near jackson heights or something, forgot.
Old Oct 18, 2005 | 11:28 AM
Muckman's Avatar
Moderator in Chief
How does #4 piston look?
Old Oct 18, 2005 | 11:30 AM
Finest's Avatar
ROFL! Werd! Good luck! (on the build and the Powerball!)
Old Oct 22, 2005 | 07:39 AM
Mrfeee1's Avatar
Go to Westchester Crankshaft, its on northern Blvd. in the 100's, go get the head vacuum tested... i got it done and they are a knowlegdeable machine shop......
Old Oct 22, 2005 | 08:12 AM
rpm11's Avatar
Looks fine, but I would disassemble the valves
in that one chamber and take em to someone
with a valve re-facer and lightly touch them up,
This will show even the smallest of bending.
Even a vacuum test can be deceiving, because
the vacuum pump can be strong enough to overcome
a very small leak,I port heads and do valve jobs
every day, this is high performance stuff,
do it right
Old Oct 22, 2005 | 10:26 AM
h22 civic's Avatar
Default Re: Is my head okay? (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">Westchester Crankshaft. Think its near jackson heights or something, forgot.</TD></TR></TABLE>
agreed
Old Oct 22, 2005 | 12:28 PM
LShatchie's Avatar
Default Re: Is my head okay? (h22 civic)
how did your rod break? I just threw a rod on my b18a1 that was completely n/a. When mine broke it bent the 2 intake valves on that cylinder. And you could clearly tell because they would not close completely because of being bent. I dont think your are bent but you should definatley inspect them first. Mine probably wouldnt have bent if I didnt keep restarting it and driving it lol. If I were to have just left it alone after it shut off it might have been ok, but I was done with the motor anyway and wanted to see if it would keep running with a huge hole in the block .
Old Oct 22, 2005 | 12:34 PM
DRAGLS's Avatar
Default Re: Is my head okay? (LShatchie)
What's the part# on those plugs?
Old Oct 22, 2005 | 03:24 PM
m R g S r's Avatar
Default Re: Is my head okay? (DRAGLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS &raquo;</TD></TR><TR><TD CLASS="quote">What's the part# on those plugs?</TD></TR></TABLE>
8 series....umm ill pull one out tonite and tell you.
Old Oct 23, 2005 | 08:54 AM
DaveF's Avatar
what intake manifold are you running?
Old Oct 23, 2005 | 08:57 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Is my head okay? (Dturbocivic)
venom
Old Oct 23, 2005 | 09:09 AM
DaveF's Avatar
must be the older version, i think the new ones are a round plenum
Old Oct 23, 2005 | 11:00 AM
m R g S r's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">must be the older version, i think the new ones are a round plenum</TD></TR></TABLE>
yep...venom
seems like the valves all seat fine. i was cleaning the carbon off the head by filling the combustion chamber with fuel, all seemed to hold the same amount of liquid
Old Oct 23, 2005 | 02:42 PM
m R g S r's Avatar
here...
h2.4
Jun 26, 2010 03:08 PM
LOKSTER
Southern California
Jan 2, 2010 08:21 AM
colnago
Mar 9, 2007 07:49 AM
turbociv
Sep 16, 2003 09:52 PM
