Valves look white, is this bad
Old Oct 17, 2005 | 07:34 AM
sbcs15's Avatar
Default Valves look white, is this bad
I took my exhaust manifold off to change the gasket, so I looked up at the exh valves and they looked white, is this normal, lean condition or what ?
Old Oct 17, 2005 | 05:24 PM
sbcs15's Avatar
bump
Old Oct 17, 2005 | 05:43 PM
doublejz's Avatar
Default Re: (sbcs15)
means nothing... could be a little lean but I have seen stock motors with white valves
Old Oct 17, 2005 | 05:49 PM
JDM_lover03's Avatar
Default Re: (doublejz)
usally it means its too hot, either your mixture is lean or you have a vaccum leak or your timing is alittle to advance, I'm not 100% sure though
Old Oct 18, 2005 | 05:46 AM
sbcs15's Avatar
bump, any body else vote its ok to have white valves
Old Oct 18, 2005 | 06:04 AM
.Ry's Avatar
.Ry
Do you let it idle alot before you shut it off? Pull ur sparkplugs and let me know what they look like. I had the issue of my plugs being white, but I was informed that at idle hondas run on the safe side of lean. Now I would assume your valve could be the same way. When you pull your plugs if they are distorted in anyway you might have a problem. I could be way wrong but it will get you started.
Old Oct 18, 2005 | 08:27 AM
Dougie Pants's Avatar
Default Re: Valves look white, is this bad (sbcs15)
Usually that would tell me the motor is running lean and hot.
eg:R
May 24, 2009 12:54 PM
TeGGY_LS
12
Jul 24, 2008 08:36 AM
92ehatch
21
Nov 13, 2007 01:58 AM
tuan...
Sep 7, 2004 04:27 PM
