GS-R Transmission
Old Oct 17, 2005 | 04:49 AM
94gsrIntegra's Avatar
Default GS-R Transmission
I was wondering if a automatic transmission is exactly the as a manual is there any thing different btween them besides the that it is an automatic?
Old Oct 17, 2005 | 05:28 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: GS-R Transmission (94gsrIntegra)
An automatic transmission is totally different. If you look on a site such as http://www.howstuffworks.com and search for "automatic transmissions" you'll see the workings of it are totally different.
EDIT: Here... How Automatic Transmissions Work
Besides it only being a 4 speed (on our cars, at least), the gear ratios are totally different.
I'm sure lots of other people will chime in with more detailed explanations involving planetary gearsets and torque converters. But I'll let them do it.
Old Oct 17, 2005 | 01:48 PM
95lstegman's Avatar
Default Re: GS-R Transmission (shamoo)
if you have a manual and you're even thinking about an automatic, try this:
drive around without ever using third gear, and even when you really want to get somewhere fast, take 2-3 times as long to shift as you would normally. on top of all this, don't downshift until 3-5 seconds after trying to accelerate in your current gear. this will approximate the BALL SUCKING of an automatic on a naturally-aspirated four cylinder car, especially one as high-strung as a GSR Integra.
if you have an automatic and are thinking about a manual, think about this:
every time you wish your automatic would accelerate the car, it will. your 1/4 mile times will drop by at least 1 full second, and an automatic GSR that used to get beaten by stock civics will now show up most other stock hondas on the road.
what is it you're trying to do? auto to manual swap? or are you trying to decide whether to buy a swap with an automatic transmission attatched?
Old Oct 17, 2005 | 02:56 PM
smakdwn's Avatar
an automatic GSR?!?!?
Old Oct 17, 2005 | 04:26 PM
95lstegman's Avatar
Default Re: (smakdwn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smakdwn &raquo;</TD></TR><TR><TD CLASS="quote">an automatic GSR?!?!? </TD></TR></TABLE>
JDM y0. automatic skyline turbos, automatic civic SiRs, and more. they have lots more traffic than we do here, and most drive less, so gas mileage is a bit less of a concern for many.
Old Oct 17, 2005 | 05:20 PM
BuyImports2's Avatar
wow, this is a broad question.... auto has 4 gears, manual has 5. Auto's shift automatically, maunals need to be shifted by the driver...lol I don't know where to start answering your question!!
Old Oct 17, 2005 | 07:38 PM
95lstegman's Avatar
Default Re: (BuyImports2)
well, the biggest performance difference is 4 gears vs. 5, slower shifts, and no control over which gear it is in. oh, and it uses up more power turning its parts.
Old Oct 17, 2005 | 07:40 PM
FULLY_BUILT_NA's Avatar
you guys know that when you push full throttle automatic down shifts right? it just does it slower than you can manually but not much slower. if you really know how to drive an auto, its ALMOST as good as a manual
and you can shift on a auto too, L,2,D3,D4 but like I said just slower than a manual shift
Old Oct 18, 2005 | 05:25 AM
shamoo's Avatar
Default Re: (FULLY_BUILT_NA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FULLY_BUILT_NA &raquo;</TD></TR><TR><TD CLASS="quote">and you can shift on a auto too, L,2,D3,D4 but like I said just slower than a manual shift</TD></TR></TABLE>
Yes, but the ratios are totally different. They are not made to be shifted, so the efficiency of shifting an automatic versus a manual is totally different. Think about how fast you can accelerate in 1st gear in a manual. You can go like 10-15mph. In an automatic, I believe you can hit over 30. That alone shows you how much more mechanical advantage a manual transmission has over an automatic.
Old Oct 18, 2005 | 07:01 AM
95lstegman's Avatar
Default Re: (shamoo)
and since the manual has 5 gears, the gears are shorter, which means you stay higher in the revs which means you go faster. by A LOT! it's like the difference between a B16 trans and an LS trans all over again. B16 faster than LS by what, 1/2 second in the 1/4? well automatic is slower than LS by a full second, so go smoke that in your VTEC for a while. if you don't have a V6 (or I4 Turbo) at least, automatics suck because it makes your car HELLA slow.
Old Oct 19, 2005 | 04:36 AM
thanks for all the input i didnt know it had only f0ur gears i thought they where the same, my tranny is grinding and i thought that i would just buy an auto and swap the internals over to my manual my because i seen auto trans go for cheap on ebay
Old Oct 19, 2005 | 07:49 AM
95lstegman's Avatar
nope. NOTHING except some bolts and maybe the vehicle speed sensor in and automatic will work in a manual transmission. just buy a used transmission or have yours rebuilt (hehe i can do it; /shameless plug).
Charlie Moua
11
Dec 31, 2005 04:23 PM
honda93
Oct 18, 2005 04:59 AM
Coyote303
Acura TL, RL & ZDX
Jun 17, 2004 09:55 PM
civicmark
Audio / Security / Video
Jan 5, 2003 09:06 PM
LordoftheAccord
Jan 14, 2002 05:08 PM
