Clutch doesn’t fit WTF?
Ok I my trans is from a jdm interga xsi 92-93 cable YS1. I have been running a act 6 puck and a stock clutch from a 93 jdm b16a with no problem ( well I hated the six puck and the stock disc exploded, but they fit) I ordered a CM 300 segmented Kevlar clutch for a 92 teg. Its too small, the ******* tranny would not go in and after wrestling with it for a while I pulled it off and put a micrometer on it.
ACT 6 Puck = 1.02ish”
CM Kevlar = >1”
Both have 24 splines if you count the inner apexes of the splines , what gives?
ACT 6 puck
CM300 Kevlar
CM Kevlar = >1”
ACT 6 puck
CM300 Kevlar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">you have a big input shaft... they sent you a clutch for a small input shaft</TD></TR></TABLE>thats simple as that the 90-91 used the samll shaft vs the 92-up all large shaft similar with the b16a discs some are larger some are small based on year
just so people know,
the good people at Horsepower Freaks dot com namely josh. (where i have spent literality thousands of dollars) told me to go expletive myself. won't be using them anymore!
i call Clutch Masters and they said no problem and gave me a return number and i shipped it out today.
i have to give clutch masters a big
and these guy are no longer in my favoriteshttp://www.horsepowerfreaks.com/
Anyone with an S1 tranny and upgraded clutch/flywheel? I have a question for you (Or if you might kn
Fred n J_v2.0
15
Jul 24, 2003 05:21 AM
stockcrx
Mar 5, 2003 06:36 PM
B20zvtecek
Sep 7, 2002 11:40 AM
