Amber Clock and Civic ?
Old Oct 16, 2005 | 05:23 PM
vandersmissenc's Avatar
Default Amber Clock and Civic ?
ok i went to a junkyard and got an amber clock and it works and all and it fits in the clock spot but everytime i turn car off and back on it resets to 1:00 how can i fix this ?
i didn't know what section to put this under if your a mod can you move it to where i will get the help i need.
Old Oct 16, 2005 | 05:30 PM
GreenEX's Avatar
Default Re: Amber Clock and Civic ? (vandersmissenc)
u need a constant power going to the clock. when u shut the car off it loses all the power and shuts off too. with a constant power it would keep its memoery. like a radio has a 12v constant and a 12v acc. wire. the 12v hold the memorey for stations and clock. 12v acc. makes it come on and work.
Old Oct 16, 2005 | 05:32 PM
Default Re: Amber Clock and Civic ? (GreenEX)
well shouldn't it already stay on or at least have a constant since it is plugged in to the clock plug ? the engine in my car is dead so im working on interior things till i get the swap in about 2 weeks and the car will still go to acc but wont start so could that be the reason the constant isn't working ?
Old Oct 16, 2005 | 05:34 PM
GreenEX's Avatar
that im not too sure about. seems if its pluged in and everything and the batt has power it should be fine.
Old Oct 16, 2005 | 05:36 PM
humm thanks i guess i will just need to mess with it some more.
Old Oct 16, 2005 | 05:47 PM
riceburnerryan's Avatar
there is a backup fuse in the engine bay ... check that....
Old Oct 17, 2005 | 03:28 AM
Default Re: (riceburnerryan)
thank you that was it the 7.5A backup fuse was blown, i didn't even think to check the fuses in the engine bay i only checked in the underdash fuse box
EF9*Hottie
Nov 7, 2007 02:00 PM
jdmjaser
Apr 16, 2006 07:41 PM
HondaPartsHero
Aug 25, 2003 05:29 PM
