how do you install a pro drive oil pump gear
Old Oct 16, 2005 | 04:55 PM
h22_crx's Avatar
Default how do you install a pro drive oil pump gear
Old Oct 16, 2005 | 10:41 PM
mgags7's Avatar
im going out on a limb here...but im gonna suggest putting the new gear in place of the old one...
Old Oct 17, 2005 | 04:46 PM
h22_crx's Avatar
Default Re: (mgags7)
how do u put it in?
Old Oct 17, 2005 | 05:38 PM
PirateMcFred's Avatar
Default Re: (h22_crx)
Go buy this and read and read and read then you will understand. It is incredably straight forward...
http://www.helminc.com/helm/pr...5C4FB
It wil help you with your limited slip install too...
Pirate
Old Oct 18, 2005 | 05:53 PM
h22_crx's Avatar
Default Re: (PirateMcFred)
thanks
Old Oct 26, 2005 | 08:57 AM
cpforyou's Avatar
Are they known for breaking just as easy as the stock OEM one? Why not just use another stock OEM one?
Old Oct 26, 2005 | 11:37 AM
The_Sober's Avatar
Default Re: (cpforyou)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cpforyou &raquo;</TD></TR><TR><TD CLASS="quote">Why not just use another stock OEM one?</TD></TR></TABLE>
OEM is probably more expensive
Old Oct 27, 2005 | 04:01 PM
bambam's Avatar
Default Re: (The_Sober)
I would install it this way:
1. put into trash can
2. install oem GSR/ITR pump
urs will eventually fail and you may have to replace other parts in ur bottom end. They don't warranty their parts either.
Sell the thing on ebay and let it be someone else's problem...
Old Oct 27, 2005 | 07:51 PM
mgags7's Avatar
why would you use a b series oil pump in a prelude motor???
but yeah you dont need that gear kid...
Old Oct 28, 2005 | 11:33 AM
h22_crx's Avatar
because the h22 i am puting in my prelude is build for turbo
Old Oct 28, 2005 | 12:16 PM
h22 civic's Avatar
Fishy_hondaman
Engine Machining & Assembly
Sep 14, 2016 12:55 PM
Hondatuner88
Jan 28, 2007 09:56 AM
UK_Luder
Nov 14, 2006 05:33 PM
fastludeh22
Oct 28, 2002 09:45 AM
Gfunk176
Jul 19, 2002 06:41 PM
