Forced Induction NGK SPARK PLUGS !!! 7's, 8's and 9's !!
PRICING GOOD TILL END OF JANUARY
<U>NGK SPARK PLUGS - </U>
Have trouble finding the correct spark plugs for your turbocharged vehicle? well look no further cuz H-T i now supply you with NGK spark plugs for your high compression/turbo needs ! cheaper than anywhere you'll find these plugs. ALWAYS in stock !
LOW LOW PRICE OF $2.10 each. plug flat rate shipping of 8.00$ around the United States ( buy 100 if you want )
<U>STOCK UP ON SPARK PLUGS TODAY !!! </U>change them every oil change and keep maintenence on your vehicle top notch. always a strong spark. never a loss in power. Why not? its <U>cheap insurance </U>against a damaged motor.
OEM honda heat range plugs are a 6 just so you can correlate the numbers.
(1 step colder)NGK BCPR7ES-11 ( sometimes ill have just the BCPR7es's only diff are the -11's are pregapped other than that its the same plug)
(2 step colder) NGK R5671A-8
(3 step colder) NGK R5671A-9
also offering NGK wires
<U>WIRE SET APPLICATIONS</U>
we accept (visa, mastercard, paypal ) <!~~ plus 3% fee's money order, cash.
PM me or email me at spoolindevelopment@gmail.com
Check out our i/c piping and manifold deals !
https://honda-tech.com/zerothread?id=1404253
Garrett/ Turbonetics/ Precisoin/ Tial specials !
https://honda-tech.com/zerothread?id=1405006
Downpipes/dumptubes for Blox/revhard/inlinepro/drag and more
https://honda-tech.com/zerothread?id=1405060
Modified by project dc2 at 8:22 AM 10/27/2005
Modified by project dc2 at 11:50 AM 10/27/2005
Modified by project dc2 at 8:45 AM 1/5/2006
Modified by project dc2 at 11:27 AM 1/15/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon »</TD></TR><TR><TD CLASS="quote">whats the difference between the BCPR7ES and the BKR-7E?</TD></TR></TABLE>
its got a projected tip
I made 8hp on the dyno switching from BCPR7ES-11 to BKR7E. (Just a FYI)
whats the diff between these and say ngk's BKR7ES ? Thats what im using right now, are these better?
one has a projected tip. perosnally i havent seen a power difference but i wont say there isnt since i dont have facts.
what step cold do i need for my setup
b16a ob1-2nd gen
garrett t3/t04e 57trim .63 a/r
rightn now im at 6psi going to be 10psi in a month or so
power range is about 240-290hp
b16a ob1-2nd gen
BCP7E's will work well until about 350 WHP
8's for 350-400
9's for 400+ or aggresive street tunes in pump gas highly recommended.
8's for 350-400
generlaly the 7's are good to 350 WHP
8's 350-400
9's 400+ and aggresive street tunes/pumpgas tunes.
if you got 7's i'd prob stick with 7's for 250 WHP. its a good plug.
8's 350-400
