car wont start help
i recently installed a z6 in my hatch, i used a p28 ecu, and i get no spark. changed the distribuitor the coil cap and rotor and nothing i checked to see if there was power on the distribuitor in there is. what elses should i look for? i also changed the main relays and no spark. thanks!
First thing to do everytime you have a no start situation is check all fuses in the fuse panel with a test light and then make sure you have fuel, fire, compression; then go from there.
Travis Davidson
Jul 3, 2024 05:20 PM
jonnybadboi9
Mar 14, 2007 06:17 PM
d16z6y8
Aug 31, 2004 01:19 PM
