Best Way to Clean Rust of Cams?
Old Oct 16, 2005 | 03:22 PM
litterbox's Avatar
I am a (Trial User) Army
Default Best Way to Clean Rust of Cams?
I've heard that you soak them in wd-40 for a while then just wipe them down. What works best?
Old Oct 16, 2005 | 03:28 PM
The_Head's Avatar
Default Re: Best Way to Clean Rust of Cams? (litterbox)
Yeah, use WD-40 and go to an autoparts store and get one of those 3M grey "scrubber" pads (very similar to the ones people use to clean dishes, but less abrasive). Lightly scrub the rust off after spraying the cams with WD.
I had a set of ZC cams that had a light layer of rust from sittting around. It worked like a charm.
Autoworks's Avatar
Brake cleaner works as well
Old Oct 16, 2005 | 03:43 PM
Phoenix1's Avatar
How bad/deep is the rust? When the engine in my 83 Prelude took a ****, I got a junkyard motor to rebuild, but water has gotten under the valve cover and I had a couple bad rust spots on the cam...so bad that machine shops said it was trash, so I sent it to Web Cam for a regrind, came out cherry.
Old Oct 16, 2005 | 04:16 PM
k24em2's Avatar
Default Re: (BlackPhoenix)
Try some naval jelly.
Old Oct 16, 2005 | 08:49 PM
2quikmotorwerks's Avatar
extra fine scotchbrite is the way to go its a burgundy color you can get it from your engine builder supply shop
BIGef
Oct 11, 2013 02:07 AM
lstecrex
Sep 12, 2008 01:22 PM
baonest
Jun 7, 2005 06:46 PM
Witty
May 9, 2004 09:19 PM
