suggestions for a 94 lude buildup
Old Oct 16, 2005 | 02:32 PM
zeroprelude's Avatar
Default suggestions for a 94 lude buildup
Im fixing to leave for IRAQ...again...im storing my 94 prelude till i get back
ill probably come back with a nice fat wad of cash to spend. Ive already done a f22 to h22jdm swap on it.
it pulls ok but deffinetly lacks low end power. vtec kicks on at around 5500 and then the thing flys. I am thinking turbo but i want to go BIG boost. Im not worried about the body since it looks sexy stock. Power first then suspension and brakes was my plan. I was going to go something like bottom to top... oil pan, crankshaft, connecting rods, pistons, sleeves, porting, rings, valves, retainers, springs, cams... intake mani, fuel, and management, that would give me a pretty strong motor to start with. then move onto a stage 3 or 4 from gearspeed tranny...welll you guys get the idea...any and all suggestions will be appreciated...
Old Oct 16, 2005 | 02:40 PM
6E LUDE's Avatar
Hey man, what branch of military are u in? Where you stationed at? I'm here in Camp Lejeune/Camp Gieger SOI as a Navy Corpsman. I have a 98' Prelude. If your in the same area maybe we can just hang out or something, check each others car.
My Car
http://webpages.charter.net/jaywahr/6%20E%20LUDE/
Old Oct 16, 2005 | 03:16 PM
AndyD's Avatar
Default Re: suggestions for a 94 lude buildup (zeroprelude)
If you wanted to boost, you should've just kept the F22.
when it comes to boosing Honda motors, do it right the first time and make sure you go to a person with a good reputation. I've seen WAAAAY too many people wasting money and blowing their motors.
Good luck in Iraq. I support you all 100%.
Old Oct 16, 2005 | 03:37 PM
Default Re: suggestions for a 94 lude buildup (AndyD)
Im going to Baquba or baqiba or whatever up in the north...FOB gabe...im stationed at fort carson with the 4th ID...stay safe
Ive got a guy lined up to do the basic engine buildup...hes got a good rep and has done great work....the porting and tranny im going to have to send out for...the tranny im thinking gearspeed "www.gearspeed.com" as for the porting havnt decided yet...thanks for the support
Old Oct 16, 2005 | 03:52 PM
preludedude94's Avatar
Hey 6E LUDE, where did you get your vinyl? And while I'm here, all you U.S. military people on here and everywhere else in the world, stay strong and come home safe!
Old Oct 16, 2005 | 06:58 PM
Default Re: suggestions for a 94 lude buildup (preludedude94)
Im aiming for at least 300whp,,,that im hoping should be enough to stopm the ever lovin cheese whiz out of any mustang i come acrosss...and yes ill have about 10 to 15k to spend...
Old Oct 18, 2005 | 04:40 PM
antballs420's Avatar
first off thanks for the protection and good luck. next, i was in the same spot ur in but. now ive got most of the **** ordered and am hoping on 400-450 whp. here is my complete engine/turbo list for ur reference. i would recomend doing this. try to come up with a list of everything ull need for the build, but take ur time selecting parts. hope my list helps.
NGINE:
Pistons/rings, rods w/arp2000 $790.00 je 9.0:1
Sleeves. $1,075.00 732-922-2309 z-10 motorsports
rod,thrust,main bearings $300.00 honda
upper and lower diff bearings $200.00 honda
Clutch- pressure plate $195.00 clutchnet yellow clutchnet
clutch-disk $100.00 clutchnet 6 puck sprung clutchnet
l.s.d. $925.00 quaife laskeyracing.com
cylinder head assembly $300.00 walters machine shop
valves $255.00 supertech laskeyracing.com
springs/retainers $300.00 supertech laskeyracing.com
headbolts $131.00 arp no limit
adjustable cam gears $120.00 aem 5-bolt Red ebay
injectors (sc10780) 780 cc $320.00 precision turbo /ask for patrick no limit
aem fuel rail $134.00 aem no limit
adjustable fpr $172.00 aem no limit
cometic head gasket $100.00 cometic hp (h1479030hp) MLS .030
timing belt kit $60.00
head set/ gaskets $60.00
3" exhaust, piping only (ss) $200.00 kteller.com
ketller 3" turbo oval muffler $187.00 kteller.com
oil $30.00 mobil one
royal purple/ purple ice coolant $12.00 no limit
TURBO:
turbo manifold $400.00 revhard shipped ebay
d-pipe $225.00 revhard shipped
turbo (sc6152e) $785.00 precision turbo no limit
dual stage boost controller $230.00 turboxs no limit
bov
wastegate $215.00 tial no limit
wastegate spring .9 bar/13psi. tial
exhaust wrap $30.00 summit
boost gauge $50.00 autometer no limit
silicone elbows/reducers $50.00 ebay
t-bolt clamps $50.00 advanced
aluminum radiator $310.00 koyo or intercooler?
hi-po fan fal
radiator cap spoon
radiator hoses obx
ECU $150.00 p28 or p72
Neptune ecu/tuning included $600.00 evans tuning. See website for checklist.
turbo timer $98.00 apexi no limit
BODY:
Paint/bodywork jet black
rim fixed usa wheels
tires $350.00 kumho ebay
springs $300.00 ground control coilovers shox.com
shocks $500.00 koni yellows shox.com
rotors $190.00 F&R Brembo drilled/slotted/zinc plated ebay
vtec caliper brackets junk yard
pads $100.00 axxis ultimate importrp.com
goodridge brake lines $125.00 importrp.com
jdm black headlights $280.00 ebay ebay
Old Oct 18, 2005 | 05:11 PM
manman's Avatar
Default Re: (6E LUDE)
Pm'd you 6E lude ( i live right next to camp lejune ) zeroprelude you should be able to toast those mustangs chasing the cheese pretty easy with that setup i run a far more ghetto setup stock engine h22a1 vtec 158k 12-14 psi depnding on my mood manual tuned fuel for fun < by me im great, been running it for 9k miles now. my front crankshaft oil seal went bad though cause it was leaking already before turbo and it was its time to go. other than that no problems 13.2 /108mph (need a stiffer rear)
Old Oct 18, 2005 | 05:49 PM
Default Re: (manman)
ive started to amke my list already...thats good advice...im worried about the rest of the motor though..i dont want to be another one of those guys that drops in all the internals cranks up the boost and blammo!!! i was looking at sending my block off to goldeneagle in cali...they have a good rep with a few guys i know and i hear they do great work...i checked out thier website and they seem like the go-to guys when it comes to engine buildup...
Old Oct 18, 2005 | 09:10 PM
dreed2300's Avatar
Default Re: (zeroprelude)
Antballs has a good list. I have done everything that he has on his list, the only thing that is diff. is a differential and an electronic boost controller. My 4th gen 2.3 lude is making 450 at the wheels with a 60-1 garrett turbo and 26x13x3 intercooler. It isn't necessary to buy a crank shaft since crank failure is very rare. But all of the other stuff is necessary to make good reliable power.
Old Oct 19, 2005 | 06:04 AM
Default Re: (dreed2300)
now a big question..(im probably gonna catch sht for this)...to keep vtec or not to keep vtec? I like it and i think i should keep it...it kicks on and my ***** end up in my guts...very cool...but some of my friends say keep it and others say ditch it...then ive read some of the threads in hre and it seems like a big deal to drive a honda without it...
remember though i said i dig it!
1994preludevtec
Jun 6, 2013 09:39 PM
Sunkenkarma
Jan 7, 2013 02:42 PM
randy.paz
Apr 14, 2006 07:40 PM
Touge Tuning
Jan 15, 2005 01:26 PM
