Someone help please!!! my da is smoking bad!!!
Old Oct 16, 2005 | 01:57 PM
g2lsv's Avatar
Default Someone help please!!! my da is smoking bad!!!
my 91 integra (ls/vtec) started puffing out white smoke a couple weeks ago, but it was on and off. and it wasnt that bad. But gradually it got worse and the last week its been really bad. So bad that i couldnt even drive it home from college so it was filling up the highway with smoke and it started to bog so i didnt wanna mess up my motor. So i towed it to my house and this weekend i worked on it. It was puffing out this white smoke that smelt bad so everyone told me its probably the head gasket...i bought a head gasket and took of my head but the gasket didnt look that bad. so then someone told me it could be the piston rings. so i opened the block and the piston rings did look bad and i changed them. i put eveerything back and started the car. but again the same problem. so now im stuck and no one has any ideas of what it could be. PLEASE SOMEONE HELP ME!!!
Old Oct 16, 2005 | 02:05 PM
Lauj87's Avatar
white smoke means theres water in the system......most likely its the head gasket....but check all your oil seals and gaskets..there might be a leak somewhere else.....not too sure what it could be if you already changed out the gasket.....and did you torque it back to spec? because over torqueing could crush the gasket too.......well good luck with the search for a solution.
Old Oct 16, 2005 | 02:32 PM
projectTeG's Avatar
did you check your sleeves head for cracks, and see if your deck and head for imperfections and straightness?
Old Oct 16, 2005 | 02:34 PM
g2lsv's Avatar
the sleeves and head are almost perfect, thats why im so confused....i dunno what it could be
Old Oct 16, 2005 | 02:36 PM
projectTeG's Avatar
but were there any imperfections or warpage?did you use copper spray?
Old Oct 16, 2005 | 04:03 PM
Kito96LS's Avatar
Default Re: (projectTeG)
ur o2sensor is fuckd up...ur runnin too rich..n thats y its smokin like a white dry smoke..the o2sensor sends a signal to the injectors to close n open in ur case the o2 is always open...supplyin the motor wit more fuel all time.
Old Oct 16, 2005 | 09:27 PM
g2lsv's Avatar
any other suggestion guys, ive tried all the above no warpage and my o2 sensor is fine
Old Oct 16, 2005 | 09:58 PM
BlackDAy's Avatar
Default Re: (g2lsv)
why didn't you do a compression and leak down test before you took everything apart?
Old Oct 16, 2005 | 10:54 PM
projectTeG's Avatar
have you checked your intake manifold for cracks? coolant could be coming in from the intake manifold...seeing that coolant runs up there too.
Old Oct 17, 2005 | 10:13 AM
g2lsv's Avatar
anyone else??
Old Oct 17, 2005 | 10:52 AM
projectTeG's Avatar
Default Re: (g2lsv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2lsv &raquo;</TD></TR><TR><TD CLASS="quote">anyone else??</TD></TR></TABLE>
check for coolant leaks on your intake manifold
Old Oct 17, 2005 | 11:36 AM
Hoonty's Avatar
Burning oil possibly?
Is it coming out of the exhaust? or from under the hood?
Old Oct 17, 2005 | 02:10 PM
g2lsv's Avatar
from the exhast, and their are no coolant leaks either
Old Oct 17, 2005 | 05:05 PM
g2lsv's Avatar
Alright guys thanks for everything....after everything i cheecked and replaced my spark plugs and that was the trick...wow i feel stupid now
Old Oct 17, 2005 | 11:39 PM
projectTeG's Avatar
Default Re: (g2lsv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2lsv &raquo;</TD></TR><TR><TD CLASS="quote">Alright guys thanks for everything....after everything i cheecked and replaced my spark plugs and that was the trick...wow i feel stupid now
wow never knew spark plugs could do that...unless the spark plug gromets were leaking and the washers on the spark plugs were bad.
derek18105
11
Nov 25, 2012 04:19 PM
Ron454321
Nov 30, 2007 03:05 PM
3rd gear vt3kc pullz hard
Jan 25, 2004 03:36 PM
thor559
Dec 9, 2003 06:42 PM
All Motor EG
Jul 22, 2002 09:48 AM
