HELp!!!!!piston ring or head gasket blown
Old Dec 9, 2003 | 06:18 PM
thor559's Avatar
Default HELp!!!!!piston ring or head gasket blown
i have a integ 98
the block is bore to 84mm build with endyn 9:1w/rings..eagle h rods..and darton sleeves...
the head is stock...(got broke after buildin my bottom.. )
well first the car kept on overheating for like a week...then i saw white smoke comin out the breather and the dipstick also...im thinking its the rings, but i don't even have over 1500 miles on it...
its a white smoke..smell sweet..this indicates a blown head gasket rite??? but is it possiable i blown the rings as well...cause smoke aslo comes out the dipstick...
when i pop the radiator cap, i can see a rainbow..so that means oil is present rite???
can somone help me out......?????
Old Dec 9, 2003 | 06:26 PM
Derek14's Avatar
Default Re: HELp!!!!!piston ring or head gasket blown (thor559)
Its definitly burning coolant... white and sweet... the HG is probly shitted...the rings shouldnt't be shot at 1500 mi., how confident are you in the build and break in? Somebody else shed some light here
Old Dec 9, 2003 | 06:29 PM
thor559's Avatar
Default Re: HELp!!!!!piston ring or head gasket blown (Derek14)
i was really inpatient so i punch it a couple of times....i buddy told me to wait for at least a 1000 but i couln't wait...i setup is ok..i reused my bearings.that was about it...
Old Dec 9, 2003 | 06:36 PM
its WANG yoO's Avatar
head gasket
but that doesn't solve the white smoke coming out the dipstick...hmmm...do a compression test.
i beleive it will be somewhat low in one of the cylinders with blown HG...with a bad ring...it will be really low!
Old Dec 9, 2003 | 06:37 PM
racinskittle's Avatar
There's controversy over the break-in. Apparently beating the **** out of it is actually better for proper ring seating.
Old Dec 9, 2003 | 06:40 PM
thor559's Avatar
Default Re: HELp!!!!!piston ring or head gasket blown (inJDMtegra)
no i didn't do a compression test...the oil from the dipstick puzzled me too..that is why i post...thx for you help...
Old Dec 9, 2003 | 06:42 PM
thor559's Avatar
Default Re: HELp!!!!!piston ring or head gasket blown (racinskittle)
wow u r the first...i thought u got to baby it for the first 1000k..???
CRuby
33
Nov 20, 2014 11:07 AM
Rxmig7
Jan 10, 2007 08:48 PM
saccord
Jan 18, 2006 08:41 PM
All Motor EG
Jul 22, 2002 09:48 AM
