Vtec Through VAFC
Old Oct 16, 2005 | 11:56 AM
Power Rev Racing's Avatar
Default Vtec Through VAFC
Ok, i read before that i can run Vtec through a VAFC. I have a 1991 civic hb. I just installed a Vtec head but the VAFC has two wires for vtec a pink and purple. One goes from ecu to vafc, then one goes from vafc to vtec solenoid. So how will I be able to hook it up to run vtec if there is no wire on my non vtec ecu to connect to vafc?
Old Oct 16, 2005 | 01:44 PM
drdisco69's Avatar
Default Re: Vtec Through VAFC (Power Rev Racing)
Yeah, the VAFC doesn't care. That wire is to appease the VTEC gnomes in the VTEC ecus, but the VAFC overrides whatever the ecu says anyway.
Old Oct 16, 2005 | 05:41 PM
91civicDXdude's Avatar
ignore the purple wire
Old Oct 16, 2005 | 06:04 PM
boosted k20's Avatar
Default Re: (91civicDXdude)
get a PR3 ecu to make the car run better. VTEC ecus have different timing and fuel curves when VTEC engages... but then again a LS timing map at high rpms is not too different from a VTEC timing map. u might suffer from a low redline unless u get the ecu chipped
Old Oct 16, 2005 | 06:09 PM
drdisco69's Avatar
Default Re: (boosted k20)
I kinda ASSumed that he would chip it and tune it anyway, but just in case, yes, you need to tune the ecu for the vtec head, and the VAFC isn't the greatest way of doing it, although it will work.
Old Oct 16, 2005 | 06:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">get a PR3 ecu to make the car run better. VTEC ecus have different timing and fuel curves when VTEC engages... but then again a LS timing map at high rpms is not too different from a VTEC timing map. u might suffer from a low redline unless u get the ecu chipped</TD></TR></TABLE>
Well the ecu is chipped for the higher fuel of vtec. Only difference is the timing i guess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">ignore the purple wire</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, the VAFC doesn't care. That wire is to appease the VTEC gnomes in the VTEC ecus, but the VAFC overrides whatever the ecu says anyway.</TD></TR></TABLE>
Thanks
tianporn
Aug 11, 2004 12:31 PM
DjFreeze
May 15, 2004 08:44 AM
jrcrx
Mar 8, 2004 11:37 PM
BlackOnBlackTeggie
Nov 30, 2003 06:25 PM
311
Oct 15, 2002 08:42 AM
