Permanent dipstick tube fix?
Old Oct 15, 2005 | 06:36 PM
Chris93Si's Avatar
Default Permanent dipstick toob fix???
Well my dipstick toob is loose again
I tried Willard's fix (https://honda-tech.com/zerothread?id=203783) and it was successful until going back to the track now it's loose again. Has anyone found a permanent fix? Will replacing the toob fix the problem? TIA guys this toob is driving me crazy
Old Oct 15, 2005 | 06:40 PM
ZygSpeed's Avatar
Default Re: Permanent dipstick toob fix??? (Chris93Si)
JB Weld it if the Honda Bond didn't work out (as long lived).
Old Oct 15, 2005 | 07:10 PM
uNF$@#!'s Avatar
Default Re: Permanent dipstick toob fix??? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">JB Weld it if the Honda Bond didn't work out (as long lived). </TD></TR></TABLE>
yep...i cant imagine jbweld ever failing on you...ever just glob it on top of the rad stick where it mates the block....i'd use jb quick unless you got something heavy to keep pressure on the thing.
Old Oct 15, 2005 | 10:54 PM
AW's Avatar
AW
Default Re: Permanent dipstick toob fix??? (255.255.255.255)
Don't you need to be able to remove the tube when you get bottom end work done?
Old Oct 16, 2005 | 05:14 PM
Chris93Si's Avatar
Anybody else???
Notice today it's not even tight when the car is cooled down anymore
Old Oct 16, 2005 | 05:47 PM
mingbling96's Avatar
loose dipstick is a sign that there's extra pressure within yr engine, most likely from piston rings not sealing correctly.
Old Oct 16, 2005 | 07:00 PM
Philly_NBP_R's Avatar
Default Re: Permanent dipstick toob fix??? (mingbling96)
^ rubbish.
Loose dipstick toob is common on the B18c5 - I think it's from the high frequency vibrations it's subject too from the high redline. I fixed mine by removing dipstick toob, cleaning it (and the mounting surface), and using Honda bond on it when replacing it - didn't have a problem after that. Honda Bond is a common sealant (similar to RTV) that is recommended for applications that are exposed to oil (like this one). You can get it from the dealer.
Old Oct 16, 2005 | 07:40 PM
Chris93Si's Avatar
Default Re: Permanent dipstick toob fix??? (Philly_NBP_R)
Tried that but only worked until I went to the track Maybe I'll try it again w/ a new dipstick toob.
Old Oct 16, 2005 | 07:50 PM
ITR640's Avatar
I still have yet to fix mine
I was talking to one of my local Acura Tech's, he suggested getting the engine up to temperature then freezing the dipstick toob (a new one of course) then installing.
Heat= expands cold= contracts
The only part that doesnt sound fun is the heat of the engine........
Don't you have to remove the header?
Old Oct 16, 2005 | 08:18 PM
Chris93Si's Avatar
Default Re: (ITR640)
I didn't remove the header the first time, just wore gloves and was careful
Old Oct 22, 2005 | 07:52 AM
B18CXr's Avatar
Default Re: (Chris93Si)
*remove it
*squeeze the end slightly with a set of slip joint pliers (making the end ever so slightly oval)
*reinstall with hammer
Old Oct 22, 2005 | 02:32 PM
Chris93Si's Avatar
Default Re: (B18CXr)
You're awesome dude, thanks
Old Oct 22, 2005 | 06:59 PM
Misfit's Avatar
or just trade the car in on something else.
RsXyDc5
May 13, 2008 02:54 PM
duckmanEG
Welding / Fabrication
10
Dec 10, 2007 05:43 PM
1998_4dr_gsr
Paint and Body
Nov 14, 2007 11:11 AM
onyx00
Jul 20, 2003 09:04 AM
IMALLSLO
May 30, 2003 05:31 AM
