how to recognize a blown head gasket
Old Oct 15, 2005 | 06:29 PM
gsrvtec2's Avatar
Default how to recognize a blown head gasket
how would u recognize a blown head gasket. what are the symptoms. and also, how do u know if u have a faulthy thermostat?
Old Oct 15, 2005 | 06:45 PM
TEG DRIVER's Avatar
Default Re: how to recognize a blown head gasket (tekneshum)
milky coolant, white smoke out of exhaust, bubbling coolant in radiator, and there may be more. i know because i have a blown head gasket right now that i am fixing for my car.
Old Oct 15, 2005 | 06:48 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: how to recognize a blown head gasket (TEG DRIVER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEG DRIVER &raquo;</TD></TR><TR><TD CLASS="quote">milky coolant, white smoke out of exhaust, bubbling coolant in radiator, and there may be more. i know because i have a blown head gasket right now that i am fixing for my car.</TD></TR></TABLE>
change the oil; it will be a color similar to a chocolate milkshake. or do a compression test, if two cylinders that are next to eachother have low compression, then its the HG.
Old Oct 15, 2005 | 06:52 PM
TEG DRIVER's Avatar
Default Re: how to recognize a blown head gasket (benb18a)
yeah my car is at the tech school right now cause i'm going to work on it in my auto tech class. do compression test, replace head gasket, change oil, and rotate and balance tires
Old Oct 15, 2005 | 07:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TEG DRIVER &raquo;</TD></TR><TR><TD CLASS="quote">yeah my car is at the tech school right now cause i'm going to work on it in my auto tech class. do compression test, replace head gasket, change oil, and rotate and balance tires</TD></TR></TABLE>
thats good. i had to do a HG on an old piece of **** volkswagen in school last year. i ******* hate those cars now
Old Oct 15, 2005 | 10:48 PM
IVI's Avatar
IVI
look under the oil cap, you may see a white milky substance forming.
droplets of oil in the coolant overflow reservoir.
white smoke out of the exhaust constatly and odor of coolant. (sweet type of odor)
contaminated oil.
upon startup the motor may hesitate due to coolant seeping through the headgasket and sitting in the combustion chamber. when starting the car the motor may bog due to the coolant being there.
compression test.
overheating almost immediatly.
bubbling in the coolant, due to compression being sent to the coolant system.
Old Oct 16, 2005 | 12:07 AM
gsrvtec2's Avatar
Default Re: how to recognize a blown head gasket (IVI)
good luck wid ur car.. my car's coolant resovoir is boiling and temp gauge rise fast. im thinking thermostat?? i hope my radiator is not busted cuz i aint got another 130 to spend
Old Oct 16, 2005 | 12:14 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">look under the oil cap, you may see a white milky substance forming.
contaminated oil.
compression test.
that about sums it up...also in a compression test it shows equall lose of compression in adjacent cylinders.
shm91
Sep 1, 2013 03:56 AM
jackfast
Mar 23, 2009 07:32 AM
NubImports
11
Mar 10, 2009 08:34 PM
4theluvofhonda
15
Jan 21, 2007 05:00 PM
CiViC I2aCeI2
Jan 20, 2006 06:49 PM
