(Boosted)B16a VS (Boosted)b18b
Old Oct 15, 2005 | 04:49 PM
PphamEK's Avatar
Default (Boosted)B16a VS (Boosted)b18b
What do u think would run stronger, b16a or b18b (both running 8 lb)
Old Oct 15, 2005 | 04:52 PM
llxzxll's Avatar
Default Re: (Boosted)B16a VS (Boosted)b18b (MugenedEK)
the b16a will have a higher hp output at the same psi, but i'm sure the LS will be able to boost safer at higher poundage
Old Oct 15, 2005 | 04:55 PM
coquitlamEG's Avatar
i'd vote for the b18b. Not only does it have more hp potential, but it's also alot easier to tune(not being a vtec)
Old Oct 15, 2005 | 05:12 PM
-Trinitron-'s Avatar
same turbo with same boost? The B18b and the b16a require VERY similar air flow. Mainly because of the displacement vs. VTEC. So, that being said a typical .54 or .60 trim compressor would be ideal for both. On the turbine side you would want to go with a .48 on the b18 and a .63 on the b16 because of the extra rpm on the b16. Either way it is going to boil down to bottom end torque on the b18 or top end power with the b16. Turbo b18...better for the track. Turbo b16...highway car. Just my .02
Old Oct 15, 2005 | 07:18 PM
The_Head's Avatar
The B18 would make more torque.
The B16 would make more horsepower.
Old Oct 15, 2005 | 08:26 PM
specv5150's Avatar
Default Re: (coquitlamEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coquitlamEG &raquo;</TD></TR><TR><TD CLASS="quote">i'd vote for the b18b. Not only does it have more hp potential, but it's also alot easier to tune(not being a vtec)</TD></TR></TABLE>
LOL
hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahaha
ch0
71
May 28, 2005 10:57 AM
EkTurboHatch
Aug 21, 2004 05:00 PM
ej1civic
May 18, 2003 01:43 PM
ej1civic
May 16, 2003 12:36 AM
PhatHardy
Apr 5, 2003 01:42 PM
