Do I need new injectors?? PLEASE HELP!!
I've got a B18C5 in my 94 Hatchback and just installed Skunk2 Stage 2 Cams, Cam gears, valvetrain AEM Fuel Rail and Regulator. Do I need 310 injectors to max out my setup or can I just up my fuel pressure? Also, I'm going to do all of my tuning via Hondata. Thanks.
Mr. Bravo, throw your car on a dyno with a wide band 02 sensor. If your engine is leaning out (a/f ratio above 13:1) anywhere in the powerband (most like up top in the rpm range) and you can't correct this by adding more fuel with a VAFC or with a ECU interface like a Hondata (I personally am using a Hondata 2a and love it) then you know you've maxed out the duty cycle on your injectors and it's time for bigger ones. A dynamic interface like the Hondata unit will actually show you injector duty cycle within the software so you can be certain what's going on with your fuel flow.
In all likelihood you'll be fine with the stock injectors with your set-up. I'm assuming you're not running high compression, so I would say it's extremely unlikely you're maxing out your stock injectors with just higher lift cams. You should be fine, but of course tune that sucker on the dyno to be sure and so that you get the most out of your cams!
Dave
Dave
Dave
Dave
Food for thought...
Jason
with 12:1 compression I think you probably will need to upgrade your injectors. I needed to with Spec B's and 12.3:1 compression, though I wasn't leaning out until over 8,000rpm on the stock injectors. Do you have a VAFC or some other way of modifying your fuel map?
Austin
bravo-
If you're running large cams and such a high compression, 310cc injectors might even be too small. I would recommend 370's and then use your Hondata system to dyno tune.
Feel free to post up that dyno graph when you're done. I think we're all interested to see what kind of power you're making.
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
How much?
Not sure...make an offer...probably should have used the IM feature, oh well.
LOL.. $17, damn, Dominic out bidded me... I am looking for injectors aswell, but I was searching for at most 370cc. Any reccomendations brand/price
[Modified by azn98R, 4:08 PM 3/6/2002]
BlackGSR
Jul 24, 2002 01:01 PM
BlackGSR
Jul 17, 2002 09:22 PM
