Aluminum exhaust piping is it ok?
Old Oct 15, 2005 | 12:21 AM
9civic8's Avatar
Default Aluminum exhaust piping is it ok?
I've searched and read and couple of posts saying its ok, and a couple saying it'll melt? Well I just picked up a b pipe, that is made out of aluminum, it's just the b pipe part, and I was wondering if it'll be ok for a daily driven car? I've already coated it with high heat anti-rust flat black paint, plus I live in CA so I don't really have to worry about rusting too much.
I just wanted to know how well does aluminum piping work for a b pipe? Thank you.
Old Oct 15, 2005 | 07:29 AM
mrbsponge's Avatar
we crunched some numbers and looked at the thermal properties of turbos and heat disipation and such, big factor is, what size is the piping? some of the SFWD guys are running 4 inch downpipes with an all aluminum exhaust. and i have even seen a 4 inch aluminum downpipe, from the math we did, it wont melt
Old Oct 15, 2005 | 09:43 AM
9civic8's Avatar
Default Re: (mrbsponge)
Thanks for the reply. The piping is 2.25" The car is mostly stock normal I/E no header, still on stock exhaust manifold. The pipe will be hooked up to a stock CAT and Apexi WS axleback. Thank you
Old Oct 15, 2005 | 10:23 AM
tony1's Avatar
Default Re: (9civic8)
Are you sure you're not confusing aluminized steel with aluminum?
Old Oct 15, 2005 | 11:22 AM
MidShipCivic's Avatar
Geoff from full race has aluminum exhaust on his 5th gen. coupe.
Old Oct 15, 2005 | 11:45 AM
ManBearPig4silly's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you're not confusing aluminized steel with aluminum? </TD></TR></TABLE>
x2 got pics of it?
Old Oct 15, 2005 | 12:22 PM
9civic8's Avatar
Default Re: (I4sillypwr)
Truth be told im not sure if it's aluminized steel or not. Here are the pictures:
I painted most of it with the anti rust paint, but left this part unpainted so I can get the flange welded on, maybe you can tell if it's aluminum or not in this pix?:
Here's the only reason why I think it's aluminum:
Any help would be awesome Thanks again guys.
Old Oct 15, 2005 | 12:25 PM
JOEY F.'s Avatar
By the way the end rusted, I dont think its aluminum.
Old Oct 15, 2005 | 12:35 PM
9civic8's Avatar
Default Re: (JOEY F.)
So it looks to be aluminized steel? Also should I sand that rusted part? Like would it be harder to weld on a new flange because it's rusted? thanks.
Old Oct 15, 2005 | 02:34 PM
cua0's Avatar
it's aluminized steel.
you should grind or sand the rust off especially if you're having it mig or tig welded.
Old Oct 15, 2005 | 04:27 PM
hulkhb's Avatar
Default Re: (cua0)
AL doesn't rust
Old Oct 15, 2005 | 04:30 PM
project dc2's Avatar
Default Re: (hulkhb)
blh blah blah its aluminized steel. alum isnt the eaiest thing to bend with a crush bender.
Old Oct 15, 2005 | 08:54 PM
Sille98's Avatar
Default Re: (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote"> blh blah blah its aluminized steel. alum isnt the eaiest thing to bend with a crush bender. </TD></TR></TABLE>
Old Oct 17, 2005 | 04:26 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (Sille98)
id ditch that exhaust.. small piping and its crush bent... your stock one probably flows better
Old Oct 18, 2005 | 03:39 PM
80884's Avatar
Default Re: (wantboost)
We have 10' sticks of that pipe at work. IMCO is the company that makes it.
I'm not a fan of crush bent piping but hey...
Too bad I don't know where to find decent priced 4" mild steel mandrel bends. We have a 10' stick of 4" at work, pretty cheap too....oh well.
Old Oct 18, 2005 | 04:35 PM
9civic8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">id ditch that exhaust.. small piping and its crush bent... your stock one probably flows better</TD></TR></TABLE>
Is it crush bent? Yes.
Small piping? Not at all. It's 2.25" ??? That's SMALL? Engine is a mostly stock SOHC besdies I and E, no Header.
How would my stock one flow better?
Old Oct 18, 2005 | 05:25 PM
wantboost's Avatar
Who is Mr Robot?
yea 2.25 is pretty small, combine that with the crush bends and the internal volume is less than a 2 or even 1.5" pipe
Old Oct 19, 2005 | 09:10 AM
beepy's Avatar
Default Re: (80884)
You aren't going to find good 4" mandrel bends easily. However you can use 4" SCH 5 pipe. A smidge heavier, but tight radius.
Old Oct 19, 2005 | 03:24 PM
Ekasey's Avatar
Default Re: (beepy)
We have goon ones in U's and 90's there just not mild steel
Employee24
10
Apr 10, 2008 04:52 AM
RACEPAK
Welding / Fabrication
16
May 7, 2005 07:34 PM
tonezilla
Mar 13, 2005 07:49 AM
PreludePhill
Feb 2, 2005 06:27 PM
