Where can i find just the plug for VTEC/VTEC oil pressure.
Old Oct 14, 2005 | 11:59 PM
hmtcrxsir's Avatar
Default Where can i find just the plug for VTEC/VTEC oil pressure.
I just did a Z6 swap in my CRX. I converted it to OBD1. But I need to hook the VTEC and VTEC oil pressure up. I dont want to spend $100 on a OBD1 engine harness and just cut it up. Its going to be a waste. Is there a site that just sells the VTEC and VTEC oil pressure plugs individually?
And can i drive the car without hooking up the VTEC and VTEC oilpressure wire up?would it affect anything at all?
yes i checked all the junkyard and none of them have a VTEC engine harness laying around.
Old Oct 15, 2005 | 12:06 AM
EG-SI(rII)'s Avatar
Default Re: Where can i find just the plug for VTEC/VTEC oil pressure. (hmtcrxsir)
You can drive it without Vtec, but don't go past the engagement point...Horror stories.
p.s. i may have an extra off my old B16, i don't know if they're the same or not?
Old Oct 15, 2005 | 12:08 AM
hmtcrxsir's Avatar
Default Re: Where can i find just the plug for VTEC/VTEC oil pressure. (EG-SI(rII))
should be the same. How much
Old Oct 15, 2005 | 12:50 AM
torzy's Avatar
d to b series they looked different to me...
Old Oct 15, 2005 | 02:24 AM
hmtcrxsir's Avatar
Default Re: (torzy)
im pretty sure the last time i did a swap using a Civic si harness with a GSR engine and it plugs right in. how can they be different?
Old Oct 15, 2005 | 08:11 AM
93CX's Avatar
Default Re: (hmtcrxsir)
VTEC Solenoids for B and D series motors do look slightly different, but they are interchangable.
JDM-MONKEY
Jan 14, 2006 10:10 AM
si0385.
Dec 8, 2005 03:41 AM
Nick-B16
Oct 8, 2004 11:43 PM
Nsane1
Jun 12, 2004 04:47 PM
vspec12
Nov 5, 2001 05:25 AM
