Nitrous + Big Cam ??
Old Oct 14, 2005 | 10:38 PM
Squirtin EGsr
Guest
Posts: n/a
Default Nitrous + Big Cam ??
This is the setup im going to be doing... B18c1 with 12:1 JE and was thinking about doing the Buddy Club 4 package deal (cams, Gears, Springs, and Retainers for 1000.00) and do a set of supertech valves.... im thinking about doing somthing like 150+ shot with it... i have the NOS GSR plate (direct port) are those cams to aggressive and should i do a differnt package ?
Also would the spec 5s be to big ?
Old Oct 15, 2005 | 10:15 AM
Squirtin EGsr
Guest
Posts: n/a
up
Old Oct 15, 2005 | 10:25 AM
f22btwincam's Avatar
Default Re: Nitrous + Big Cam ?? (Squirtin EGsr)
squirt it, this isn't the correct forum so check in the forced ind. there are a couple people who are knowledgeable with nitrous the key is tunning with nitrous
Old Oct 15, 2005 | 12:34 PM
ghostofnyc's Avatar
ask cubish or 1700anddroping
Old Oct 15, 2005 | 03:33 PM
Squirtin EGsr
Guest
Posts: n/a
there needs to be a nitrous fourm on here damn it
Old Jan 16, 2006 | 09:50 PM
Ls1 FD3s's Avatar
Default Re: (Squirtin EGsr)
honda owners are dead skurred of n20...
Old Jan 17, 2006 | 05:54 AM
westfire25's Avatar
Default Re: (Ls1 FD3s)
Well I'm no expert on nitrous but I'm spraying a 75 wet shot on skunk2 pro 1's with 11:5:1 compression so all I can say is make sure you get it tuned properly. It took almost a day to get it tuned (because it is jdm itr pistons which are cast not forged) but was well worth it when done. You could ask cubish or 1700and dropping they are the ones who can help you out a lot.
Old Jan 17, 2006 | 06:25 AM
Used2beAb16's Avatar
Default Re: (westfire25)
you will be fine with that setup, dont spray till your tuning.
Icey112
Jun 26, 2005 04:47 PM
CIVICLUDE
Jun 11, 2005 06:44 PM
cjames235
Sep 20, 2002 07:47 AM
TypeR-R6
Aug 2, 2002 02:28 PM
95gsr
Jun 16, 2001 07:57 PM
