brake rotor size
Did some searching but couldnt find exactly my answer...WIll the rotors made for a Del Sol with ABS fit one that doesnt have ABS? Can i drill out the screws holding the rotors or are they just there to look pretty?
As long as I dont have to take out any more Metal Gears
It should matter if its ABS or not. It also depends on whether u have a delsol S or VTEC. The VTEC model should have 10.2 inch rotors in the front, which are the same for integras, civic EX's, and 99-00 SI. I'm not sure what size the delsol S or SI uses. The little screws are tough and they actually help hold the rotor in place. U will need an impact driver tool to get them off
The Del Sol S, Si and VTEC model all have differnt size Rotors depending on year and such. The VTEC sol rotors will not fit any other del sol. The Rotors Screw are usless drill them out and toss them away, I am sure your lug nuts will do a good enough job holding the rotor in place.
gmacarize
12
Oct 27, 2008 06:26 PM
b16nonoy
May 22, 2006 12:45 PM
delsolnewkid
Mar 13, 2006 07:20 AM
