------- Odometer not working after reinstalling ECU ---------
Old Oct 14, 2005 | 02:46 PM
Wilky's Avatar
Default ------- Odometer not working after reinstalling ECU ---------
I have a P28 chipped from Ih8ricerz w/ jdmsh!t obd1-2 harness. After experiencing idle problems in my Si, removing the ecu, and later reinstalling it, the Tachometer no longer works - no response at all
What do I need to do to get this working? No pins seem to be bent or missing, by the way.
EDIT: It is my Tachometer! not my odometer
Modified by Wilky at 2:38 AM 10/16/2005
Old Oct 14, 2005 | 04:15 PM
rainforest's Avatar
Default Re: ------- Odometer not working after reinstalling ECU --------- (Wilky)
check the fuse 25 under you dash. it goes to the cluster. most likey a fuse if it happen that quick. or check the jumper harness the vss imput to the obd ecu is at b10 and on the obd2 it is at c18
Old Oct 14, 2005 | 06:37 PM
Wilky's Avatar
Default Re: ------- Odometer not working after reinstalling ECU --------- (rainforest)
I thought about the fuse, but when I reinstall the stock ecu, the tach works again. I will check those contacts: but does anyone have a diagram or link?
Thanks
Modified by Wilky at 7:58 AM 10/17/2005
Old Oct 14, 2005 | 07:22 PM
slomofo's Avatar
GDD Member
If you reinstall your stock ECU and the odometer works, then don't you think that there is a problem with your new ECU?
Some idiot probably burned off a wrong pin while socketing your new ECU.
Old Oct 15, 2005 | 05:37 PM
Wilky's Avatar
Default Re: (slomofo)
It worked before on the same car. Of course I thought about that. Here's the deal:
I am an idiot because i said odometer and I meant Tachometer!!!!
Anywho... I went from stock ecu to chipped ecu. Then, after doing some work and getting idle/ richness issues, I had to go back to the stock ecu. So... after reinstalling the chipped obd1 p28 ecu, the Tachometer no longer worked.
Help. I need this ecu because it will soon be used for Crome on my turbo SOHC.
Old Oct 16, 2005 | 10:58 PM
Wilky's Avatar
Default Re: (Wilky)
Bump for further assistance
Old Oct 17, 2005 | 02:45 AM
1750cc's Avatar
Default Re: (Wilky)
probably its wiring issue from the obd2- obd1 converter. check for the diagram and verify the pin if its connected for the rpm at the gauge.
Old Oct 18, 2005 | 09:12 PM
Wilky's Avatar
Default Re: (Wilky)
Old Oct 19, 2005 | 06:44 AM
Wilky's Avatar
Default Re: (Wilky)
Diagrams anyone?
Old Oct 19, 2005 | 09:40 AM
iH8RICERZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">
Some idiot probably burned off a wrong pin while socketing your new ECU.</TD></TR></TABLE>
some idiot huh?! Looks like you really know what your talking about. From the 4 years of doing ecu's.... I've never heard of a problem with the Tachometer from the ecu's I've chip. Check your harness...PM Newman or contact jdmshit to see if it is a wiring problem from their harness.
Old Oct 19, 2005 | 12:56 PM
Wilky's Avatar
Default Re: (iH8RICERZ)
Yeah. All evidence is pointing to the harness.
And to slomofo: iH8RICERZ is not some idiot who doesn't know what he is doing. Search around on this board and ask people "in the know." They will all tell you, he definitely knows what the hell he is going on with chipping/socketing and ecus in general.
Kid-jdm-teggy
17
Jan 28, 2015 08:57 PM
LOMPSEG
Engine Management and Tuning
Apr 2, 2009 08:52 PM
89civicdxracer
Jan 20, 2005 08:34 AM
lopey
May 1, 2002 11:26 AM
chuckd05
Nov 6, 2001 08:13 AM
