96 gsr block build help requested
Old Oct 14, 2005 | 10:39 AM
standinghollow's Avatar
Default 96 gsr block build help requested
I got myself a block from a 96 gsr with crank,main caps and girdle.It will eventually be going in my 94 ls.My question is since its an obd-2 block do i have to get internals from a 96 up gsr or can i use 94-95 internals at all? Like oil pump, windage tray,pickup tube,
rear main retainer,water pump and timing belt covers?It will be getting built for turbo,possably benson sleeved.I know im going to need obd-1 head too.
Old Oct 14, 2005 | 10:54 AM
Kendall's Avatar
The year of the internals and/or the head doesn't matter. The only difference between the OBD-1 motors and the OBD-2 motors is the electronics, and the oil pump. If you plan on running the motor as an OBD-2 motor, then you'll need to the OBD-2 oil pump with the correct timing gear and sensor, the OBD-1 oil pump doesn't have the sensor.
Old Oct 14, 2005 | 10:56 AM
Default Re: (Kendall)
Ill be running obd-1 so ill get obd-1 oil pump anything else i need to know?Would any b16 parts work?
Old Oct 14, 2005 | 11:16 AM
TheBobFather's Avatar
Default Re: (standinghollow)
get the type r pump the best imo
Old Oct 14, 2005 | 11:52 AM
Kendall's Avatar
Default Re: (jnbhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jnbhonda &raquo;</TD></TR><TR><TD CLASS="quote">get the type r pump the best imo</TD></TR></TABLE>
The ITR pump is no different than any other OBD-2 oil pump.
And for reference sake, the OBD-2 pumps do outflow the OBD-1 pumps and will work just fine and dandy with any OBD-1 setup.
Old Oct 14, 2005 | 12:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
And for reference sake, the OBD-2 pumps do outflow the OBD-1 pumps and will work just fine and dandy with any OBD-1 setup.</TD></TR></TABLE>
for this reason^^^^^^^^^
rak511
Feb 28, 2014 12:08 PM
Turbo-GSR1287
Apr 12, 2008 08:20 AM
EM1_00Si
Jul 3, 2007 05:52 PM
92integraVTECgsr
Mar 17, 2006 06:25 AM
blu3g
Aug 9, 2005 04:31 PM
