I'm Stumped!!
Old Oct 14, 2005 | 05:52 AM
JODYG35950's Avatar
Default I'm Stumped!!
I have a crx with a B18A1 (only the bottom end is built with 10:1 Comp) running all bolt-ons including full MSD with SCI+ box, all lightweight pulleys,crank pulley, flywheel. My problem is under normal driving the car seems to be fine, but when I get on it ANY, it acts like someone just wrapped their hands around its neck and is choking the @#$& out of it. I just doesn't want to go. I have triple checked timing (although the timing adj. conn. doesn't seem to do anything), triple checked my valve lash, my fuel is at 44psi with vac. on. Any other ideas?
Old Oct 14, 2005 | 09:26 AM
JODYG35950's Avatar
Default Re: I'm Stumped!! (JODYG35950)
bump
Old Oct 14, 2005 | 08:20 PM
Kendall's Avatar
Are you sure it's not a problem with the MSD? You'd be surprised at how good the stock Honda ignition really is.
Old Oct 14, 2005 | 09:15 PM
wanabericer's Avatar
Default Re: (Kendall)
yup i hate msd messes with alot of things like frying ignitors
Old Oct 18, 2005 | 08:29 AM
JODYG35950's Avatar
Will stock ignition work well for any forced induction. That is my next step for performance.
Old Oct 18, 2005 | 08:38 AM
drdisco69's Avatar
Default Re: (JODYG35950)
Yes. The Honda ignition system is awesome, respek it. Always use Honda plugs, wires, cap, rotor, etc, otherwise horrible misfires will ensue.
Old Oct 18, 2005 | 08:44 AM
JODYG35950's Avatar
Default Re: (drdisco69)
Okay, I will trade it all out to see if that helps any. Thanks for the advice.
Old Oct 18, 2005 | 08:51 AM
Hecdosage's Avatar
Any luck with that problem yet? I had an msd kit and i was having the same problem. I found that it was messing up my sparkplugs then I would replace them the car would run fine for awhile. Then the plugs would fry again. I got rid of it and the problem went away.
Old Oct 18, 2005 | 09:01 AM
drdisco69's Avatar
Default Re: (Hecdosage)
LOL, dude, it's been 7 minutes since he posted, doubt he's got it fixed yet.
Old Oct 18, 2005 | 09:12 AM
Hecdosage's Avatar
Hey it does not take long to remove the msd kit all you have to do is unplug it and run just stock.
Old Oct 18, 2005 | 01:51 PM
JODYG35950's Avatar
I am at work right now, I'll swap it out tonight cause my stock coil is at home. I'll post my results tomorrow. Thanx for the help.
Old Oct 18, 2005 | 07:22 PM
Slow ass EF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JODYG35950 &raquo;</TD></TR><TR><TD CLASS="quote">Will stock ignition work well for any forced induction. That is my next step for performance.</TD></TR></TABLE>
yes it will, my friend boosted jeff is running stock ignition, and thats all Jeff Evans runs in any of his cars
Old Oct 20, 2005 | 07:40 PM
JODYG35950's Avatar
I took off my MSD and went back to stock ignition and coil. Car runs much better now. Thanks for all your responses so quickly. Honda ignition is much better!!!
Old Oct 20, 2005 | 07:58 PM
Jim Truett's Avatar
https://honda-tech.com/zero...ge=12
/\ This car runs a stock LS distributor. It's a B20 with a PR3 head and VTEC Killer Cams. It's seen 9700 rpm on the Dyno, and put down 232 WHP on a large Dyno Jet (very conservative number). The stock ignition is good past 10,000 rpm, and I've personally seen it used for a 620whp FI Civic.
kuba_guzik110
Audio / Security / Video
Oct 5, 2013 12:47 AM
red civic standard
May 22, 2005 05:42 PM
2.2XDreams
May 24, 2004 12:34 PM
SB97civic
10
May 17, 2004 07:49 PM
96LudeSiVTEC
Feb 23, 2003 11:54 AM
