NO HEATER PLEASE HELP
Old Oct 13, 2005 | 10:35 AM
j spec's Avatar
Default NO HEATER PLEASE HELP
got a 94 cx hatch, which is a factory no a/c car. for some reason the heater will not blow hot air. put in a new heater core, flushed the system, the cable is opening the heater box, and its not the engine cause its done it even after i did the swap? please help
Old Oct 13, 2005 | 01:14 PM
LOGICx420x's Avatar
Default Re: NO HEATER PLEASE HELP (roma's h22eg6)
You should check your compressor...
Old Oct 13, 2005 | 03:35 PM
rainforest's Avatar
Default Re: NO HEATER PLEASE HELP (LOGICx420x)
check that the heater valve is opening. there is a valve that will bypass the heater core when shut. its on the pass side fire wall. the cable could be streached or the valve could be broke. and why the hell did you put in a new heater core if it wasent leaking?
Old Oct 14, 2005 | 09:03 AM
j spec's Avatar
Default Re: NO HEATER PLEASE HELP (rainforest)
its my friend's car the heater core was leaking the valve is opening but it could be broke hadnt thought to check that thanks
Old Oct 14, 2005 | 09:04 AM
j spec's Avatar
compressor?
Old Oct 14, 2005 | 11:20 AM
THEUSED's Avatar
this may sound stupid but check your radiator fluid
Old Oct 14, 2005 | 12:02 PM
amckee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roma’s h22eg6 &raquo;</TD></TR><TR><TD CLASS="quote">compressor?</TD></TR></TABLE>#1 You said it's a factory 'no a/c' car. No a/c = no compressor. #2 Whats the compressor got to do with heat? Have you checked to see if the air mixer door in the blower assembly is switching from fresh air to the heater core duct?
4g4dcruisin
Oct 6, 2011 03:00 PM
Shaw14
Dec 21, 2009 12:30 PM
B1B-EK
Nov 17, 2005 03:47 PM
j spec
Oct 14, 2005 09:06 AM
s2kkid
Sep 26, 2004 03:56 PM
