Using a stroker crank with eagle rods made for B18c1..
Old Oct 13, 2005 | 08:12 AM
pane93civhb's Avatar
Default Using a stroker crank with eagle rods made for B18c1..
I was trying to find out if I could use a stroker crank on my b18block with Eagle rods and my choice of pistons .. i want to get some greater displacement.. since im boosting the car. U guys have any suggestions on which crank to get. How much of a stroke i will want to get out of it. im going to bore the cylinders to 84mm and get it sleeved by bensons.. thanks any input would be great..
Old Oct 13, 2005 | 01:47 PM
non-VTEC's Avatar
Default Re: Using a stroker crank with eagle rods made for B18c1.. (pane93civhb)
if you re-sleeve your B18 to 84mm you already increased the displacment to 2.0L
how much more do you want with a stroker crank?
Old Oct 14, 2005 | 07:35 PM
slomofo's Avatar
GDD Member
On a B18C1
Bored to 84mm - 1932cc - 1.9L
84mm w/89mm Crank - 1971cc - 2.0L
84mm w/92mm Crank - 2038cc - 2.0L
84mm w/95mm Crank - 2104cc - 2.1L
95 is the longest stroke available for b-series off the shelf aftermarket cranks, 89mm is the LS crank.
Old Oct 16, 2005 | 07:25 AM
How do u guys think that the 95mm crank will run on boost .. How will it effect my rev's and what crank would u suggest really looking for opinions maybe there is someone in here who has had this setup..
sleeved block B18c1 with 84mm bore and XXX crank or should i leave the crank stock. Will i not have a better torque curve if i get a crank that matches the setup better.
Old Oct 16, 2005 | 07:58 AM
NJIN BUILDR's Avatar
Default Re: (pane93civhb)
Bigger displacement=more power sooner.Bigger bore gives you more flow potential.More stroke gives you more torque sooner.If you don't have rules limiting your engine size don't worry about bores/strokes.Just go big and let reliability and money be your limiter.
Glenn
Old Oct 16, 2005 | 08:18 AM
Default Re: (NJIN BUILDR)
Nice.. well rules matter since i wana do it right and i dont wana choose a setup that wont work well. Like the 84 bore with the 95 stroke .. IF i cant rev to 9g's then i dont wana go that route do u feel me. Im not so worried about the money .. I dont want to have to keep rebuilding my motor every 6 months either though. If ima do it do it right the first time.
mike11
Northern California (Sales)
11
Feb 2, 2012 12:21 PM
93xsi
Oct 18, 2010 09:42 AM
cherryhatch00
Jan 15, 2007 02:57 PM
turbotypeR@SPEC
Dec 5, 2004 10:51 AM
baonest
May 27, 2002 09:20 PM
