high compression pistons
Old Oct 12, 2005 | 11:50 PM
redlude94's Avatar
Default high compression pistons
i dont want to spend 1000$ to sleve an engine but i do need high compression i know if i use oem pistons i dont have to sleve but y do i have to sleve with aftermarket if i get them std or .25 os ??
Old Oct 13, 2005 | 07:12 PM
NJIN BUILDR's Avatar
Default Re: high compression pistons (redlude94)
Oversize pistons plus .25mm or .50mm are fine with unsleeved cylinders.You need to have high compression pistons tuned correctly and run high octane fuel to keep from cracking sleeves.Most of the reason all motor cars sleeve is to get bigger displacement.
Glenn
Old Oct 14, 2005 | 07:41 AM
redlude94's Avatar
well im talkin about an h22 when dont i have to sleeve i was always told i have to sleeve if i put any non oem pistons in
Old Oct 14, 2005 | 12:00 PM
b18bturbo's Avatar
H22 with the FRM liners its always best to sleeve to aftermarket pistons. The oem and now the mahle pistons are an alternative. The Gold Series mahle can be used with the FRM liners.
Old Oct 14, 2005 | 03:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlude94 &raquo;</TD></TR><TR><TD CLASS="quote">well im talkin about an h22 when dont i have to sleeve i was always told i have to sleeve if i put any non oem pistons in</TD></TR></TABLE>
I guess that mentioning that it was a H22 would have been good info to include in your post. Like was said the Mahle or OEM are your options without sleeving.
Glenn
gtseviper2
Nov 10, 2013 11:49 AM
accordmatt
Jun 23, 2011 06:09 PM
team 15
Jun 22, 2007 03:49 AM
Pippen_001
16
Jul 28, 2006 07:48 PM
H22A_HB
Sep 3, 2004 08:43 PM
