OBD2b-OBD1 conversion, autometer tach works but not stock tach?!?!
Old Oct 12, 2005 | 03:43 PM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default OBD2b-OBD1 conversion, autometer tach works but not stock tach?!?!
i have a 2000 acura integra LS 5spd and swapped out my obd2b ECU for a OBD1 p75 w/conversion harness. i made the swap because im going to have a straight pipe and don't want that stupid engine light into limp mode. i swapped out the ECU and my stock tach doesn't work BUT my autometer one does! i put back my OBD2b ECU and both the stock and autometer tachs work. HOW CAN I HAVE MY STOCK TACH WORK WITH MY OBD1 ECU? do i need to mess with the ignitors or something? PLEASE HELP...!
Old Oct 13, 2005 | 09:11 PM
Default Re: OBD2b-OBD1 conversion, autometer tach works but not stock tach?!?! (integra_LSR)
to the top!
Old Oct 13, 2005 | 10:16 PM
00IntegrAllmotoR's Avatar
HT Black OPs
want to know to going to be doing this with my Turbo setup soon!
Old Oct 14, 2005 | 02:43 AM
LL2009's Avatar
Default Re: OBD2b-OBD1 conversion, autometer tach works but not stock tach?!?! (00IntegrAllmotoR)
i converted my 98 teg to odb1 and everything works fine. i think something may be wrong with your odb1 ecu try a different ecu and see what happens.
Old Oct 14, 2005 | 02:33 PM
Default Re: OBD2b-OBD1 conversion, autometer tach works but not stock tach?!?! (LLEO245)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LLEO245 &raquo;</TD></TR><TR><TD CLASS="quote">i converted my 98 teg to odb1 and everything works fine. i think something may be wrong with your odb1 ecu try a different ecu and see what happens. </TD></TR></TABLE>
well my car is a 2000 which is obd2B and yours is a 1998 which is a OBD2A. and i got the ECU straight outta my buddys car where everything functioned perfectly
Old Oct 14, 2005 | 02:37 PM
98 Spec R's Avatar
I bet there is a problem with the adapter.
Old Oct 14, 2005 | 02:49 PM
Default Re: OBD2b-OBD1 conversion, autometer tach works but not stock tach?!?! (98 Spec R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98 Spec R &raquo;</TD></TR><TR><TD CLASS="quote">I bet there is a problem with the adapter.</TD></TR></TABLE>
ok if its the adaptor, wouln't both my stock and the autometer one not work? my autometer tach works tapped off of my stock tach signal behind the stock tach cluster.
Old Oct 15, 2005 | 11:04 AM
anyone with suggestions?
Old Oct 16, 2005 | 07:27 PM
bump
Old Oct 19, 2005 | 04:19 PM
i know someone knows here
Old Oct 21, 2005 | 08:21 PM
again
Old Oct 27, 2005 | 02:13 PM
bump
MastaFlyMason
Oct 9, 2016 12:35 PM
Muckman
Jul 3, 2013 10:20 AM
MOVE OVER
Engine Management and Tuning
11
May 18, 2008 03:00 AM
bboyfreeze
Apr 25, 2007 08:57 AM
2000integrals
Jul 23, 2005 07:51 PM
