Ball joint removal
Old Oct 12, 2005 | 02:17 PM
SRCivic97's Avatar
Default Ball joint removal
I've read several threads about this but none are clear on once you have seperated the Lower LCA from the Ball Joint, how do you actually get the Ball Joint out.
Old Oct 12, 2005 | 02:24 PM
SRCivic97's Avatar
Default Re: Ball joint removal (SRCivic97)
Ball Joint removal tool is what Im hearing.
Old Oct 12, 2005 | 02:32 PM
bradykiller's Avatar
They have to be pressed out, it would be much easier and cheaper to just buy a semi used new one.
Old Oct 12, 2005 | 02:35 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRCivic97 &raquo;</TD></TR><TR><TD CLASS="quote">Ball Joint removal tool is what Im hearing.</TD></TR></TABLE> Will require a vise as well.
Old Oct 12, 2005 | 02:45 PM
SRCivic97's Avatar
Default Re: Ball joint removal (HondaFanatic708)
To buy a used ball joint? To buy what exactly used. If you have a picture that would be great.
I can either pay $210.00 parts & labor at Honda or I can buy the tools and do it myself. I know how to seperate the LCA from the ball joint. But getting the ball joint out is my main concern.
Old Oct 12, 2005 | 02:56 PM
Remove knuckle from car. Use balljoint tool and a vise to press out the old one and press in the new one.
Modified by HondaFanatic708 at 6:13 PM 10/12/2005
Old Oct 12, 2005 | 03:06 PM
SRCivic97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">a vise to press out the old one and press in the new one. </TD></TR></TABLE>
Remove the whole assembly and stick it in a vise? then press it out?
Old Oct 12, 2005 | 03:11 PM
pdiggitydogg's Avatar
You need to remove the knuckle from the car.
Then, when you have the entire assembly in your hands, just whack the stud side with a damn hammer. Who cares if the threads are mushroomed? Youre replacing it!
As far as putting a new one in, however, it will need to be pressed into the knuckle.
Again, a big hammer will easily pop the ball joint from the knuckle
Old Oct 12, 2005 | 03:12 PM
You have to use a ball joint remover/installer. The kit will usually consist of 3 part. You put the tool on the balljoint and tighten the castle nut. Then there is a base to put on the opposing side of the ball joint so as you tighten the vise it has a cavity to push out into. Remove the old balljoint from the tool. Flip tool over and use the installer base to press the new balljoint in.
Here is a link to this section in the service manual.
SRCivic97's Avatar
Default Re: (pdiggitydogg)
Thanks man, that's what I was looking for.
Old Oct 12, 2005 | 03:17 PM
Default Re: (SRCivic97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRCivic97 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks man, that's what I was looking for.</TD></TR></TABLE>NP, try going to an auto parts store and see if they rent one. That would be your cheapest option.
JohnWayne
Jun 15, 2006 11:08 PM
squeaky
14
Aug 29, 2004 12:08 PM
ultraforce77
Jul 15, 2004 02:59 PM
Rywire
Mar 11, 2004 12:21 PM
Flamenco-T
Aug 21, 2002 11:49 PM
